So I take it Toyota has no new transmissions in stock?
Is there a doc case that, a well maintain tranny (Let say have changed at least two times on oem spec tranny oil and filter within 100k miles), and still need a replacement?
I have a Y2K with 89K miles, based on the service records (Dealer service the entire life), they replaced the tranny oil and filter once, can't recall when and mileage, should I go do it again?
No new transmissions period. No longer made.
I found this thread after I bought my 2000 LC... 153k...and it sounds good so far...
This is actually not necessarily the truth.
What happens is if you order a "reman" tranny from Toyota, and they do not have any reman's in stock, they will actually send you a new one in a reman container.
Quick Update:
I picked up the LC last Friday and have put about 750 miles on it, yep I drive a good bit. At first I had that felling that something was not quite right but after a few adjustments, by that I mean shaving off the tops of the slider mounts that were rubbing my floor boards
I just noticed my MT sliders are rubbing the floor board (DS) also.
I bumped them recently out on the trail.
Do you know if MT is aware of this problem?
How much did you have to shave off the bracket?
Anyway, Onur your recommendation seems really helpful on the tranny fluid. Would you recommend that for all years, as well? I have an 01.
