ARCHIVE The Official Tube Notching Thread (6 Viewers)
I typically lay stuff out in CAD. I have 3 CAD programs to choose from.
Since I got the Bridgeport, I am thnking about making a jig so I can use endmills to notch.
How do people like the holesaw notchers?
fine pitch roughing end mills are the shizzle. when regular four fluted end mills will pull the end of the tube in, the roughing mills typically won't...
Did some test notches today for you guys......
Baileigh TN-250 Tube & Pipe Notcher with Radial Vise Tubing Notching Pipe Coping Machine
whats up with the web site, every link you click on for a price it says "call for a quote" exactly why i dont use that site.
great tools but too much a pain in the butt to put prices together and come up with a price for a upgrade or something.
cheers
cheers
Not sure what website you are talking about, but ours has the pricing right on it.
http://metal.baileighindustrial.com/tube-notcher-tn-250
Let me know if you have any other questions.
No kidding. I went to the first one google said and every link said call for prices. My bad. I will look here. Ty
Cheers.
Wow- that end notcher is the s***!
So hot! Want to touch the hiney!
Hello
Ron here. As you can see from most of the conversation that $ is the biggest issue.
I find the drill press to be the best of the low $ notchers.
Use the best name brand hole saws you can get. USE STICK WAX on them.
If you are not into math and want to get good at the "eyeball it" or make a pattern.
Start off with PVC , HF hole saws,and magnetic angle finder for your drill press.
If you have a plastic[pvc] template then use that to set your angles a first timer
will be very happy.
If you want a clue as to "go slow"? hand a 10 pound weight off the handle of the drill press
and set the speed one higher then the lowest speed it cuts.
HF drum sanding kit and a roll of emery paper will take care of 'fine" tuning on your drill press.
