Hi Folks,
I thought I'd start a more technical fuel consumption thread for the HDJ81, taking all kinds of factors into account, so as to give more accurate fuel consumption assessments for this vehicle.
Feel free to cut and paste and edit as required, it can be used as a template for your own measurements, and publish your own findings
All record data: distance, speed, consumption is corrected for accuracy based on highway markers for distance and stopwatch measurements with highway markers while driving at a constant speed +/- 1kph for 4km for speed. US Gallon at 3.78 l, Cannuck Gallon at 4.54 l. Mile at 1.609km. Brim to brim fuel filling, engine at operating temperature during filling.
Hope y'all find it useful
Chris
HDJ81 Fuel Consumption Records
Vehicle Specs:
Model: HDJ81 Landcruiser VX LTD
Year: 1991
Mileage: ~83,000km
Drive: Full-Time Four Wheel Drive
Transmission: A442 Automatic, Std valve body, 3 speeds + overdrive
Axles: Lockable Factory Differentials, Lockable Center Differential
Gearing: Factory - Unknown
Engine:
Model: Toyota 1HD-T
Type: Inline-6 Diesel Engine
Displacement: 4.3l
Optimum Torque Region: 1,700 RPM to 2,400 RPM
Maximum Power: 165HP at 4,300 RPM
Fuel Technology: Direct Injection
Valve Technology: Belt-driven Overhead Cam, 2 valves per cylinder
Admission: Single Stage Turbo Charger
Intercooler: none
Propane Injection: none
Record 2 (I will publish the record for my first test in November of last year when I have access to all my data):
Date: May 5, 2007
Engine Temperature: Normal Operating Temperature between Fill-Ups
Driving Conditions:
Road Surface: Dry
Type: Highway
Altitude: 75% 0-300m
25% 300-1000m
Temperature: 10-20C
Speed Travelled: 90% at 97kph +/- 3kph 98% of the time (highway)
10% AT 68 kph +/- 10kph, variable (state/provincial)
Wheels:
Rims: Berg Alloys 16"x8"
Tires: Brand: Bridgestone Dueler A/T
_______Type: Radial, LT, Load Range C
_______Size: 285/75/R16
_______Wear: 90% Worn
_______Actual Diameter: __ 32.25"
_______Actual Tread Width: 9.25"
_______Inflation Pressure, PSI:
___________________________Front: _ 40
___________________________Rear: __ 44
Lubrication:
Engine: Mobil-1 20W50 Racing Synthetic, for 8,000 km
Transmission Lubricant: unknown, presumed OEM
Transfer Case Lubricant: unknown, presumed OEM
Differential Lubricant: unknown, presumed OEM
Speedometer and Odometer Correction Factors, this Vehicle and Conditions, averaged out based on four mesurements:
_________Indicated___Measured____Method___________Corr. Factor___Accuracy
Speed___ 92 KPH _____ 97 KPH ___ Stopwatch _ ______1.055__________+/-0.005
Odom.___ 88.1 KM ___ 59.0 Mi ___ Highway Marker ___1.077__________+/-0.002
calculated OEM Tire Size Extrapolated from Odometer versus Actual Distance: 32.25 / 1.077 = 30.00"
Actual Speedometer Correction Factor Versus Odometer: 1.055 / 1.077 = Speedo Reads 0.98 Times Actual Speed with 30.00" OEM Tire
Actual Results, Corrected from Real Measurements:
Fuel Consumed: 12.697 US Gallons (brim to brim filling) at 3.78l/US Gallon = 47.99466l
Distance Travelled, Actual: 500km
Calculated Fuel Economy:
Metric: 9.6 l/100km
US Measure: 24.47 MPG
Imp. Measure: 29.39 MPG
On my way back from the States, 50% town highways and short stop and go, 50% highway at 97 KPH, I managed 9.7l/100
Tomorrow, when I get to the gas station, I'm going to measure my fuel consumption over the last stretch, which I did at approx. 108-110kph average, just for the heck of it. I did notice the fuel was going down a wee bit faster than at 95-100. I expect the figure to be around 11 to 11.5 l/100, based on the fuel tank needle position.
Bottom line, you can make this beast as thrifty as a camel
My next challenge: break the 30MPG (Imperial) barrier
Chris
Vehicle Specs:
Year: 1991
Mileage: ~83,000km
Engine:
Model: Toyota 1HD-T
Displacement: 4.3l
Intercooler: none
Date: May 5, 2007
Driving Conditions:
Road Surface: Dry
Type: Highway
25% 300-1000m
Temperature: 10-20C
Wheels:
Lubrication:
Metric: 9.6 l/100km
