The Evolution - Toyota Land Cruiser (1 Viewer)
78fj40mg
TLCA #23510
PNW, WA.
Website
forum.ih8mud.com
I came across these Toyota Land Cruiser Evolution charts and thought this is a must share topic. Sorry if these pics have been re-posted or cross posted somewhere else on MUD.
Toyota Land Cruiser - The Evolution
Please share your related pics.:)
Toyota Land Cruiser Model BJ Series (1951-1955)
  • The Land Cruiser currently has the longest running history in the Toyota lineup. With origins from the Toyota Jeep BJ which was created in 1951, the name "Land Cruiser" has since been used from the release of the 20-series in 1955. (See pic above)
The automobile industry was in a fateful crisis from Japan's defeat in war and the chaos that followed it. However, military procurement enabled a recovery and the combination of the accumulation of technology from before the war and present material resulted in the development of an automobile above expectations.
The chassis of the Toyota Jeep BJ was based on the SB-type 1-ton truck (with an S-type 995cc engine) that was originally released in 1947. For that reason, at 2,400mm the wheelbase about 200mm longer than that of the Jeep, and the body was also a size larger. The SB-type compact truck was commonly known as the Pony Toyota (and later the Toyopet Truck), and because it was designed as a small transport vehicle that could also double as a passenger car, its suspension settings were likewise soft. These characteristics were carried over into the Toyota BJ-type, so it gave a surprisingly comfortable ride.
The engine was a 3,386cc water-cooled in-line 6-cylinder B-type gasoline engine. Jeeps being built at that time had a side valve construction, but the B-type engine was an OHV (Over Head Valve) type. The engine was originally designed in 1937, with the first prototype completed the next year in 1938, after which it was installed in the GB-type truck, the KB-type truck, and the BM-type truck, being primarily an engine for 4-ton class trucks.
The capacity of the B-type engine when it was first developed was a maximum output of 75HP/3,200rpm, and a maximum torque of 21kgm/1,600rpm. Later these specs were improved by boosting the compression ratio and through other refinements, so that whereas the first model Toyota Jeep BJ model had a maximum output of 82HP/3,000rpm and a maximum torque of 21.6kgm/1,600rpm, by the late model version the power had been boosted to a maximum output of 85HP/3,200rpm and maximum torque of 22kgm/1,600rpm. This meant reserve power for the size of the body it was mounted in, so the Toyota Jeep BJ came without a LO range subgear.
The Toyota Jeep BJ was completed in 1951, and first unveiled that same year at a public showing of Toyota vehicles. There were 26 Toyota vehicles displayed at this event, and during the 3-day period the attendance amounted to some 200,000 people. Moreover, the design of the Crown was begun in 1952, with the first Crown model built in 1955.
At the time it was considered unusual to say the least to match a 4-ton truck engine with a compact truck chassis, but in reality these were the only materials that Toyota had to work with. It turned out to be a successful combination. An ample sized body useful for transporting materials driven by an engine with power to spare, this model met multiple needs in the market for a compact 4x4 vehicle at a high level. Moreover, the fact that it was not adopted for use by the Police Defense Forces actually turned out to be a major stimulus for the development of an export strategy, with considerably more freedom in design and development, and became a key factor in Toyota's successful overseas launch.
However, in 1953 Toyota did receive a procurement order from the National Police Agency, and the plant in charge of production was the Arakawa Bankin Kogyo KK (now called ARACO Corporation). With regular orders for large-scale production, the factory literally worked around the clock to meet demand. The process worked like this: first the parts for the chassis would be shipped from Toyota Motor Corporation for assembly at the Toyoda Automatic Loom Works, Ltd., then transported to the Arakawa Bankin Kogyo KK, where the body was painted. The completed vehicles would then be shipped overland back to the Toyoda Automatic Loom Works, Ltd., where they would be inspected by officials from the National Police Agency, whose demands could be met by a team of about 20 people who could do finishing work and make adjustments.
The Toyota BJ-type was a multi-purpose compact truck based SB-type truck, and went through a series of body shape design changes over time. The original short body hooded cargo and passenger carrier type was converted to a metal top type, and a closed type passenger model was also released. For the cargo carrying version the rear was extended by 500mm and converted to a pickup truck, and there was also a truck with a separate unit cabin and truck bed. There were many variations according to where the spare tire was located, not only on the rear gate, but even on the front fender or below the truck bed.
Because the body has a rather squeezed nose design, the diameter of the steering wheel covers about half of the instrument panel. For that reason the driver's seat feels rather cramped, and when you carry a passenger it makes it a bit difficult to steer. In the later 20-series models the steering wheel was moved further to the outside.
The Toyota BJ is essentially an SB-type chassis mounted with an engine built for a 4-ton truck. It was originally developed in response for a bid from the National Police Reserve Forces, like the Willys Jeep, but there were several significant differences between the two models. One difference was the engine. The Willys Jeep had a 2.2-liter compact in-line 4-cylinder engine mounted in a compact body. By contrast, the Toyota BJ-type vehicle had a 3.4-liter large-sized in-line 6-cylinder engine.
The so-called B-type engine not only had a larger piston displacement, but also structural differences. Build for effectiveness on the battlefield, the Willys Jeep had pursued a low hood profile, and consequently was built with side-valve type cylinder heads. The Toyota BJ-type on the other hand, with its larger piston displacement and cylinder head structure, was better suited to the dawning new age of the 4x4.
There were also differences in the power train. From the BJ-type to the subsequent Land Cruiser 20-series there was no LO gear in the transfer. As a part-time 4x4, the transfer lever extending from the floor only triggered a switch from 2WD to 4WD mode. The 3.4-liter engine had strong torque from the start, so there was no particular need to secure extra torque by means of a complicated subgear in the power train. However, the 4-speed transmission also came with a low gear, the 1st gear having a low gear ratio of 5.53 in the 1st gear compared to the final gear ratio of 4.11, a result of its being based essentially on truck specifications. The low gear ratio in the transmission also limits the maximum speed you can get out of the vehicle, but at the time there were few paved roads, and for a car designed from the start for limited applications this was not a problem.
The National Police Reserve Forces elected to go with the Willys Jeep for their procurement program, but in many respects the Toyota BJ was a superior vehicle. It had a larger piston displacement, a longer wheelbase, and a larger body. Moreover, its softer suspension settings reduced fatigue on the driver, all of which contributed greatly to Toyota's later success in penetrating overseas markets. By the time large-scale production began in 1953, the Toyota BJ had already paved the path to overseas markets.
  • The leaf springs were supported by a full-floating front axle, 9 plates each with a 1,000mm span, a 45mm width, and 6mm thickness. The spring brackets were fixed by rivets.
  • The leaf springs were supported by a semi-floating rear axle, 10 plates each with a 1,150mm span, a 45mm width, and a 6mm thickness. There was lots of friction between the leaf springs while driving, which effectively reduce vibration to the body.
  • The ladder type frame on the Toyota BJ was built so that the distance between the side frames grew narrower as you approached the front. The front was narrower at the front in order to support the heavy front-mounted engine, while the rear was wider to provide stability for the wheels. There were 3 cross-members, with the side frame between the first and second cross-member being made of a high-strength box-enclosed type structure.
Birth of The Toyota Jeep BJ
The history of the Land Cruiser began just after World War II in 1950. The drastic rise in inflation in Japan after World War II resulted in enormous living difficulty for citizens and thus resulted in the implementation of the "Dodge line" economic stabilization policy in Japan by the U.S.A. in 1949. The extremely strict austerity measures of this financial and monetary contraction policy at last brought inflation under control. However, the drastic change in policies had a dampening effect on industrial production activities, and Japanese industries faced an even more serious period of difficult times.
The resulting recession had a direct impact on the automotive industry, making it difficult to obtain funds and requiring companies to revise production plans and cut back staff. This resulted in regular conflicts with labor unions, and in April of 1950 Toyota suffered a large-scale strike. The dispute was eventually resolved in June, after a major management shuffle. However, production levels dropped during the strike, and the monthly production during that time was only a few hundred units per month. This period was truly one of the most difficult periods for Toyota as a company. On June 25 of 1950 the North Korean (Democratic People's Republic of Korea) suddenly invaded the South Korean (Republic of Korea), and the Korean War had begun.
At that time Japan was still under the influence of America, centering on the occupation forces of the United States military, for which Japan played a role as a supply base, and with the Korean War all military production went into full time operation. Orders were issued by the headquarters of the occupying forces for large numbers of military trucks. This was a special demand tied directly to the Korean War.
When the National Police Reserve Forces (now called the Japan Self-Defense Forces) was first established it depended entirely on the U.S. Military for all of its equipment, however very quickly it was urged that domestic sources of supply be developed. Part of the motivation was to create a base in Japan through which the U.S. Military could procure military vehicles for use throughout the Asia region, but Japanese automakers were asked to produce prototypes for compact 4x4 trucks and other vehicles.
In response Toyota began designing such vehicles in August of the same year, and by January of 1951 had produced a prototype. The prototype was a truck with a B-type gasoline powered water-cooled in-line 6-cylinder 3,386cc engine, installed on a SB-type 1-ton truck chassis.
At the time there were many Jeeps being driven in Japan, which had been brought in by the occupying forces, and the Jeep came to be the symbol of the 4x4. For this reason Toyota called its prototype the Toyota Jeep, and by combining a B-type engine with a Jeep model it was known as the BJ.
However, the vehicle which was ultimately selected for procurement by the National Police Reserve Forces was the Willys Jeep. The Toyota Jeep BJ had been rejected on this project, but in July of the same year test driver Ichiro Taira did a test run under the supervision of officials from the National Police Agency, and performed brilliantly, climbing by car all the way up to the No. 6 checkpoint on Mt. Fuji. The test run was viewed favorably, and in August this model was officially adopted as the patrol car for the National Police Agency.
However, large-scale production of the Toyota Jeep did not begin until August of 1953. It took 2 years from the decision to adopt the prototype to get ready for full-scale production, most of the time being required for detailed decisions on the specs and on price negotiations. But orders were placed in blocks covering the fiscal year, as one would expect from a government agency. In the first year 298 Toyota Jeep BJs rolled off the production line. Later, in addition to the patrol car for the National Police Agency, Toyota also received orders from the Forestry and Agricultural Agency and from Electric Power companies.
The next year in June of 1954, responding to claims of trademark violation by the Willys Company that produced the original Jeep, then Director of Technology Hanji Umehara renamed this 4-wheeled vehicle as the Land Cruiser. The rest as they say is history, as the Land Cruiser demonstrated global competitiveness with its rival models, and its success proved it to be truly worthy of its name.
Sakichi Toyoda founded the Toyoda Automatic Loom Works, Ltd., to which he dedicated his entire career. Successor to the intelligence and active spirit of his father, Kiichiro Toyoda established the company in the automotive industry. His dream was to produce an automobile that could gain acceptance throughout the world, and certainly Toyota has taken that major step.
Model AK10, Specification
Overall, Length...................3,390mm
Overall, Width.....................1,570mm
Overall, Height....................1,800 (1,370)mm
Wheel Base........................2,300mm
Tread, Front/Rear................1,300mm/1,300mm
Minimum Turning Radius........6.0m
Vehicle Weight....................1,100kg
Payload.............................500kg
Seating Capacity.................2 Passengers
Gross Vehicle Weight............1,800kg
Engine Type.......................Gasoline engine, 4-cycle, OHV
Number of Cylinders..............4
Bore and Stroke...................84.14mm x 101.6mm
Displacement......................2,258cc
Compression Ratio................6.0
Maximum B.H.P....................43HP at 2,800 rpm
Maximum Torque..................17.0kg-m at 1,400 rpm
Maximum Speed...................80km/h
Gasoline Tank Capacity.........50L
Really super Mike-thanks for sharing!
A very rare J20, J30 (1955–1960) Land Cruiser
J20/J30
Overview
Also called
Toyota Bandeirante (Brazil)
Production 1955–1960
Assembly
  • Toyota city, Japan (ARACO)
  • Sao Bernardo, Brazil (Toyota do Brasil)
Body and chassis
Body style
  • 2-door soft-top
  • 2-door hardtop
  • 2-door pickup truck
  • 5-door station wagon
Layout FR layout
Powertrain
Engine
3.4L Type B Inline 6
The 3,386 cc (3.4 L; 206.6 cu in) Type B was produced from 1937 through 1955 as a more technically advanced version of the Type A. The design was based on the Chevrolet 207 engine, and built under license but with metric dimensions and minor revisions to suit the local market. It had a four-bearing crank and shaft-mounted rocker arms, as did the Chevrolet engine.
Type A engine (for reference only)
Possibly a Type B engine (could not verify)
3.9L Type F Inline 6
The Type B was succeeded by the similar 3.9 L Type F in 1955. The Type F is based on the larger G.M.C. 1939-63 L6 OHV engine in the same way that the Type A and Type B were based on the Chevrolet engines of their times.
Wheelbase
  • 2,285 mm (90.0 in)
  • 2,430 mm (95.7 in)
  • 2,650 mm (104.3 in)
  • 1955 – The Second generation, 20 Series was introduced. It was designed to have more civilian appeal than the BJ for export reasons. It also had more stylish bodywork and a better ride thanks to longer four-plate leaf springs which had been adapted from the Toyota Light Truck. It had a more powerful 135 PS (99 kW) 3.9 L six-cylinder Type F gasoline engine, but still only had a three speed gearbox. The interior of the vehicles were made more comfortable by moving the engine 120 mm (4.7 in) forward. The 20 Series still had no low range, but it had synchronism on the third and fourth gears.
  • 1957 – A 4-door Station Wagon was added as the FJ35V on a 2,650 mm (104.3 in) wheelbase. Land Cruisers were first imported into Australia by B&D Motors as FJ25/28 cab chassis with Australian made bodies. They were the first Japanese cars to be regularly exported to the country and a few were initially used in the Snowy Mountains Hydroelectric Scheme, by sub contractor Theiss Constructions.
  • 1958 – FJ25 production commenced in Brazil; this being the first Toyota vehicle built outside Japan. These were sold as the "Toyota Bandeirante" from January 1962 when the Toyota petrol engine was replaced with a Mercedes-Benz diesel engine. The FJ25 models were built until August 1968 in Brazil. Production numbers were fairly low; in 1965 the total came to 961 vehicles.
Toyota Land Cruiser Model FJ40 Series (1960 -1984)
Models
1981 Land Cruiser FJ40
The Toyota J40 is the model designation for a Toyota Land Cruiser 40 series made from 1960 until 1984 (in Brazil, where it was known as the Toyota Bandeirante, it was made from 1968 until 2001). Most 40 series Land Cruisers were built as 2-door SUVs with slightly larger dimensions than a Jeep CJ.
The model was available as the FJ40 series (with F engines) and also BJ40/41/42 (short wheelbase), BJ43/44/46 (middle wheelbase) or HJ45/47 (long wheelbase) designation where it had a Diesel engine. Land Cruisers built in Brazil from 1968 to 1993 - with Mercedes-Benz engines - received OJ40/45 (OJ50/55 from 1973) series chassis codes and those built from 1994 to 2001 - with Toyota engines - have BJ50/55 series model codes.
History
For the history of the J series from the original 1951 Toyota Jeep BJ through the J20 series see Land Cruiser History from 1950 to 1955.
  • 1960: J40 series launched (wheelbase 2,285 mm (90 in)/2,430 mm (96 in)/2,650 mm (104 in)).
  • 1963: Longer wheelbase (2,950 mm (116 in)), FJ45-B, pickup and cab-chassis were added).
  • 1967: End of four-door FJ45V (I) (w/b 2,650 mm (104 in)) production, replaced by FJ55 Station wagon).
2-door FJ45-B renamed FJ45 (II) (w/b 2,950 mm (116 in)).
  • 1968 40-series production commences in Brazil, with local Mercedes-Benz diesel engine[1]
  • 1973?: HJ45 launched with the H, 3.6-litre inline 6-cylinder diesel engine.
  • 1974: BJ40/43 launched with the B, 3.0-litre inline 4-cylinder diesel engine. A factory-fitted roll bar becomes standard in the United States (FJ40).
  • 1975: Rear ambulance doors are added to US model FJ40s. The lift gate remains available as an option in other countries.
  • 1976: Disc brakes on the front axle.
  • 1977: Front door vent windows, removed, vent windows on the hard top in the United States
  • 1979: Power steering (only F models) and air conditioning added to the options, gear ratios modified from 4:11 to 3:70 in the United States to be more freeway friendly
  • 1980: HJ47 launched with a 4.0-liter six-cylinder diesel engine. End of HJ45 production.
BJ42/46 and BJ45 launched with a 3.4-liter four-cylinder diesel engine.
  • 1981: Power steering added on the BJ models to the options, disk brakes added in Australia.
  • 1984: End of J40 series production (replaced by J70 series).
  • 1993: Five-speed transmission becomes available for the Toyota Bandeirante.[2]
  • 1994: In Brazil, the Mercedes-Benz OM-364 engine is replaced by the Toyota 14B unit.
  • 2001: End of Bandeirante production.
Land Cruiser FJ43
Pics coming soon
BJ40/41/42
(short wheel base)
Pics coming soon
Pics coming soon
Pics coming soon
1975 Land Cruiser FJ45 pickup
1963 Toyota Land Cruiser Station Wagon (FJ45)
  • The J40/41/42 was a two-door short wheelbase four-wheel-drive vehicle, with either a soft or a hardtop (V). It was available with various petrol or diesel (from 1974) engines over its lifetime. It was replaced on most markets from 1984 by the J70 series (70/71).
    • The FJ42 is 4X2 model, for only The Middle East.
  • The J43/J44/46 was an extremely rare two-door medium wheelbase four-wheel-drive vehicle, with either a soft or a hard-top (V). It was replaced on most markets from 1984 by the J70 series (73/74).
  • The J45/47 was a long-wheelbase four-wheel-drive vehicle, available in two-door hardtop, three-door hardtop, four-door station wagon and two-door pickup models. The four-door station wagon model (FJ45V-I) was the shortest-lived of the J40 series, as it was replaced by the FJ55G/V in 1967.
  • The Bandeirante TB25/TB41/TB51 Series are J25 series Land Cruisers built in Brazil by Toyota do Brasil Ltda from 1962 to 1968. In 1966 they were replaced by the OJ32 (soft top) and OJ31 (hard top) for the TB25, and the TB81 for the TB51; for an unknown reason the TB41 would keep its J2 code until 1968 when Toyota do Brasil switched to the J40 series.
  • The second generation Bandeirante OJ40/OJ45 Series (1968 to 1973), OJ50/OJ55 Series (1973 to 1994) and BJ50/BJ55 Series (1994 to 2001) are J40 series cars built in Brazil by Toyota do Brasil Ltda from 1968 to 2001. Identical to the BJ40 in almost every respect, it had a few stylistic modifications to the grille (models produced from 1989 on featured square headlights, instead of the round ones used before) and used Mercedes-Benz OM-314/OM-324/OM-364 diesel engines (replaced by Toyota 14B inline 4 direct injection Diesel engine in 1994) for much of its production life; another visible mayor characteristic are the entire hind doors (like at Land Rover) rather than the traditional Toyota two-wing hind doors at the Bandeirante's hard top models.
The Bandeirante Models (Brazil)
4011260148842d1229477845-vendo-toyota-bandeirantes-longo-1994-a-copia-de-dsc02124.jpg
  • 1968:
    • OJ40L - Short soft top bushdrive car - motor Mercedes-Benz OM-324 (September 1968 to January/February 1973) - replaces the OJ32L
    • OJ40LV - Short hard top bushdrive car - motor Mercedes-Benz OM-324 (October 1968 to January/February 1973) - replaces the OJ31L
    • OJ40LV-B - Long hard top bushdrive car - motor Mercedes-Benz OM-324 (October 1968 to January/February 1973) - replaces the TB41L
    • OJ45LP-B - Short pickup with native bed - motor Mercedes-Benz OM-324 (September 1968 to January/February 1973) - replaces the TB81L
  • 1973:
    • OJ50L - Short soft top bushdrive car - motor Mercedes-Benz OM-314 (February 1973 to November 1989) - replaces the OJ40L
    • OJ50LV - Short hard top bushdrive car - motor Mercedes-Benz OM-314 (February 1973 to November 1989) - replaces the OJ40LV
    • OJ50LV-B - Long hard top bushdrive car - motor Mercedes-Benz OM-314 (February 1973 to November 1989) - replaces the OJ40LV-B
    • OJ55LP-B - Short pickup with native bed - motor Mercedes-Benz OM-314 (February 1973 to November 1989) - replaces the OJ45LP-B
  • between 1973 and 1989:
    • OJ55LP-B3 - Short chassis-cab pickup - motor Mercedes-Benz OM-314 (19?? to November 1989) - new in 19??
    • OJ55LP-BL - Long pickup with native bed - motor Mercedes-Benz OM-314 (19?? to November 1989) - new in 19??
    • OJ55LP-BL3 - Short chassis-cab pickup - motor Mercedes-Benz OM-314 (19?? to November 1989) - new in 19??
    • OJ55LP-2BL - Long 2-door double cabin pickup with native bed - motor Mercedes-Benz OM-314 (19?? to November 1989) - new in 19??
  • 1989:
    • OJ50L - Short soft top bushdrive car - motor Mercedes-Benz OM-364 (November 1989 to April 1994) - replaces the OJ50L with Mercedes-Benz OM-314 motor
    • OJ50LV - Short hard top bushdrive car - motor Mercedes-Benz OM-364 (November 1989 to Abril 1994) - replaces the OJ50LV with Mercedes-Benz OM-314 motor
    • OJ50LV-B - Long hard top bushdrive car - motor Mercedes-Benz OM-364 (November 1989 to Abril 1994) - replaces the OJ50LV-B with Mercedes-Benz OM-314 motor
    • OJ55LP-B - Short pickup with native bed - motor Mercedes-Benz OM-364 (November 1989 to Abril 1994) - replaces the OJ55LP-B with Mercedes-Benz OM-314 motor
    • OJ55LP-B3 - Short chassis-cab pickup - motor Mercedes-Benz OM-364 (November 1989 to Abril 1994) - replaces the OJ55LP-B3 with Mercedes-Benz OM-314 motor
    • OJ55LP-BL - Long pickup with native bed - motor Mercedes-Benz OM-364 (November 1989 to Abril 1994) - replaces the OJ55LP-BL with Mercedes-Benz OM-314 motor
    • OJ55LP-BL3 - Long chassis-cab pickup - motor Mercedes-Benz OM-364 (November 1989 to Abril 1994) - replaces the OJ55LP-BL3 with Mercedes-Benz OM-314 motor
    • OJ55LP-2BL - Long 2-door double cabin pickup with native bed - motor Mercedes-Benz OM-364 (November 1989 to Abril 1994) - replaces the OJ55LP-2BL with Mercedes-Benz OM-314 motor
  • 1994:
    • BJ50L - Short soft top bushdrive car - motor Toyota 14B - April 1994 to November 2001 - replaces the OJ50L
    • BJ50LV - Short hard top bushdrive car - motor Toyota 14B - April 1994 to November 2001 - replaces the OJ50LV
    • BJ50LV-B - Long hard top bushdrive car - motor Toyota 14B - April 1994 to November 2001 - replaces the OJ50LV-B
    • BJ55LP-B - Short pickup with native bed - motor Toyota 14B - April 1994 to November 2001 - replaces the OJ55LP-B
    • BJ55LP-B3 - Short chassis-cab pickup - motor Toyota 14B - April 1994 to November 2001 - replaces the OJ55LP-B3
    • BJ55LP-BL - Long pickup with native bed - motor Toyota 14B - April 1994 to November 2001 - replaces the OJ55LP-BL
    • BJ55LP-BL3 - Long chassis-cab pickup - motor Toyota 14B - April 1994 to November 2001 - replaces the OJ55LP-BL3
    • BJ55LP-2BL - Long 2-door double cabin pickup with native bed - motor Toyota 14B - April 1994 to November 2001 - replaces the OJ55LP-2BL
  • 1999:
    • BJ55LP-2BL4 - Long 2-door double cabin pickup with native bed - motor Toyota 14B - 1999 to November 2001 - new in 1999
Paint color codes
Code Color
012 Cygnus White
031 White (?-'80)
033 White ('80-)
113 Health Grey
309 Freeborn Red
310 Capri Blue
414 Buffalo Brown
415 Pueblo Brown
416 Dune Beige
464 Beige
Traditional Beige
474 Dark Copper
532 Mustard Yellow
611 Dark Green
621 Rustic Green
622 Nebula Green
653 Sicilian Olive
681 Green
(Nicknamed "John Deere Green")
808 Horizontal Blue
822 Royal Blue
854 Sky Blue
857 Nordic Blue
Feel Like Blue
Toyota Color Codes 1961 - 1971
full
Toyota Color Codes 1964 to 1967
coolfj40_2271_9375863
Toyota Color Codes 1968 to 1969 #1
coolfj40_2271_9631893
Toyota Color Codes 1968 to 1969 #2
coolfj40_2271_9933745
Toyota Color Codes 1970
coolfj40_2271_10093225
Toyota Color Codes 1971
coolfj40_2271_10568531
Toyota Color Codes 1972
full
Toyota Color Codes 1973
full
Toyota Color Codes 1974
full
Toyota Color Codes 1975
full
Additional color codes
  • FJ40, White, Cygnus White, 1971 to 1975, Color Code T-12
  • FJ40, White, 1976 to 1979, Color Code 031 (Pictured, Left)
  • FJ40, White, 1980 to 1983, Color Code 033
  • FJ60, White, 1982 to 1987, Color Code 033
  • FJ62, White, 1988 to 1990, Color Code 045
  • FJ40, White, Cygnus White, Hard Top, Front Grille.
  • Late model FJ40s ('82, '83) wheels, Color Code T-12 PPG-833
Engines
Over the years Toyota has changed the engines used in the J40 series. The B series motor is a 4-cylinder diesel, and the H series a 6-cylinder diesel. The diesel engined trucks were never sold to the general public in the USA, though some found their way in as mine trucks. The engines are similar, within the series. For example, the F and 2F engines share many of the same parts. However the H and 2H engines have almost nothing in common. There are individual models within the engine series, for example, there is an F125 engine, and an F155 engine, all in the F series with different power ratings. Here is a list of some of them (the power and torque figures may vary depending on the market):
Gasoline
Engine Capacity (L) Power (hp) Torque Used
F 3.8 105/125 189 lb·ft (256 N·m)/209 lb·ft (283 N·m) 1960–1975
2F 4.2 135 210 lb·ft (285 N·m) 1975–1984
Engine pics
F 3.8 ~ 1973
attachment.php
2F ~ 1978
full
F125 and an F155 engines
Features
  • While not legal in some countries, most J40 series vehicles could have their roof and doors removed. With a folding windshield this allowed for complete open-air experience.
  • The J40 Series also featured folding jump seats behind the passenger and drivers seats. These folding seats not only made carrying another 2 passengers possible, but also allowed for maximum cargo space, as opposed to the folding rear seat in the Jeep CJ series.
  • Original factory winches were driven directly from the transfer case (known as P.T.O. or power take off) powered by the engine. Later models had an optional electric winch.
The Toyota B engine family was a series of inline-four diesel engines.
Toyota also had a 3.4 L (3389 cc) inline-six gasoline engine from 1937 to 1947 that was also called the B engine. The earlier engine was used in early Toyota cars and trucks and in the first version of the Land Cruiser when it was known as the BJ Jeep. The later engine was used in later versions of the Land Cruiser. The two engines are unrelated and were not made at the same time.
Toyota made 5 generations of the B family engines, each one identified with a number before the B letter. Also, Toyota uses a series of letters to identify technical improvements to their engines:
- The number 1 (one) before the number of the engine model means that the engine uses direct injection, otherwise, indirect injection
- The F letter after the B letter means that the engine is multivalvular. Since the B family are inline-fours, that means that the engine uses 16 valves.
- The T letter, means that the engine is turbocharged
- The E letter, means that the engine is electronically controlled engine control unit (ECU)
For example, the 15B-FTE Engine is the fifth generation of the B engines, comes with 16 valves, is turbocharged, direct-injected and uses an ECU.
B Engines
Available in Japan from 1974 to 1980 (model years) in the BJ40
and BJ43, the B engine was available in Canada from 1978 to
1980 in the BJ40.
· displacement: 2977 cc
· injection: indirect
· horsepower: 80 at 3600 rpm
· torque: 141 ft-lbs at 2200 rpm
· valves: 8 ohv
· bore: 95 mm
· stroke: 105 mm
· compression ratio: 21:1
compression pressure
. normal: 30.0 kg/cm2 (427 psi) or more
. minimum: 20.0 kg/cm2 (284 psi)
. difference: 2.0 kg/cm2 (28 psi) or less
B Diesel Engine
2B Engines
Available only in Japan from 1980 to 1982 (model years) in the
BJ41 and BJ55.
· displacement: 3168 cc
· horsepower: 93 at 3600 rpm
· torque: 159 ft-lbs at 2200 rpm
· valves: 8 ohv
2B Diesel Engine
2B Diesel Engine
3B Engines
The most widely used engine from this series. It apparently came
in at least three versions with slightly different stats. One
difference is that until 1986, it came with an inline injection
pump, and then after 1986 it had a rotary injection pump. In
Japan the 3B was used from 1981 to 1990, but Canada stopped
importing vehicles with this engine in 1987. The 3B is found in
the BJ42, BJ43, BJ45, BJ60, BJ70, BJ73, and BJ75. This engine
is a favourite to turbo because like most turbo engines, it has oil
nozzles that spray the bottoms of the pistons.
· displacement: 3431 cc
· horsepower: 90, 93 or 98 at 3500 rpm
· torque: 159, 163, or 167 ft-lbs at 2200 rpm
· valves: 8 ohv
· bore: 102 mm
· stroke: 105 mm
· compression ratio: 20:1
3B Diesel Engine
full
3B Diesel Engine
Toyota Bandeirante OM 364 / 709 - Mercedes Benz Diesel Engines
Motor OM 364
Torque: 27 KGFM 1400 RPM
POTENCIA: 90 CV 2800 RPM
5697218399181d1362678087-bandeirante-1985-basica-x-ranger-1999-xlt-completa-1360776808_481899918_3-toyota-bandeirante-jipe-capota-de-aco-chassi-longo-diesel-salvador.jpg
Fascinating! I would like to find reprints of the first two charts.
Mike,
Lots of cool info. That photo in post #8 that you thought might be a B series 6 cylinder isn't. It's some 4 cylinder engine (the file info says Toyota S-series), just look at the number of wires coming off the distributor. I can delete this post if you'd rather keep the thread clean.
