I know, that's a bold statement. But let's talk about this.
Along with other members, I have lodged my complaints with the 8-speed transmission. It shifts abruptly; first gear is too low; it hunts between 1st and 2nd after coasting, etc. All of these complaints were based on a completely stock setup.
I recently upgraded my 2016 LC to 285/65R18 KO2s. Above all else, the most dramatic thing I have noticed is that the 8-speed transmission seems substantially more at home with larger (and heavier) tires.
With stock tires, I would be shifting to second before I cleared the intersection of a 4-way stop. The acceleration was touchy and the shift to second was too hard. Now, the transmission feels completely at home. First gear has a purpose; it seems perfectly geared for the larger tires. Acceleration is smooth but not jerky. The truck also shifts at a slightly higher speed, which seems to reduce the punch when shifting to 2nd. The heavier tires may also mitigate some of the shift harshness. Candidly, I still get a little hunt between 1st and 2nd after coasting, but it seems less common now.
On a related (but off-topic) note, I enjoy the brakes better with larger tires, too. On stock tires, they were just too grabby--especially as you approached a full stop. With the larger tires, the brakes seem much more balanced.
I recall from reading elsewhere on this forum that the LC is shipped with larger tires on 17" wheels in other countries. But I also recall reading that the 8-speed was only introduced in the U.S. market. So while it may be pure coincidence, I'm going to go out on a limb and suggest the 2016+ LC was actually designed for a larger-diameter tire than stock. I'll even speculate that the ever-present quest for better fuel economy may have dictated smaller stock tires but that the engineers knew many buyers would opt for larger tires later.
Maybe it's all in my head, but I'm interested if others agree.
