Since no one wants to use this section, I will......
When you do the scuba mod, do you need to remove the cover off the breather on the axle? If so, how do you remove it? If not, do you just get a tube that fits over it?
go to any truck supply
ya need 1- 1/8" -1/4" push on for plastic airline male & 1-female & what ever length of 1/4"line ya want.
remove vent install male fitting in axle push in tubing route to where ya want clean old vent install in female push new fetting on to tubing attach
OH! it does come in colors even yellow
Ha Ha what about black or black and yellow together!
beach cruiser said:Can I use one switch for 4 fog lights that I'll have up on my roof?
beach cruiser said:The light bar is a big project. I figure I'll burn out my HID's by the time that project is ready to mount up.
Yeah, I found a set on ebay for cheap.Did you buy 2 more lights?
beach cruiser said:Yeah, I found a set on ebay for cheap.
I mounted the 2 I already had this morning. The other 2 should be here in a couple days. I only have one switch thoug.
That's an easy fix. I'm sure you could find another switch. Any interest in a NOLA wiring session any time soon? I would like to get with Kevin and Bart and knock mine out so I can concentrate on bigger and better things.
beach cruiser said:Let's do it now. I'm back from the parade.
I don't have the stuff, do you? I wanted to add a fuse block, and some 12 gauge wire but I have not purchased any of it.
