Tech Stream Help (1 Viewer)
LA
Good day all,
I have a 2014 LX570 only about 80k miles on it. Not really having any issues with it other than changing the water pump a few months ago, AHC pump service that went terribly wrong but managed to work itself out in the end, and a little bit of a rough idle. None the less for all of that still one of the most reliable vehicles we have owned, next to our 4Runners. To the point, I have been looking a version of Tech Stream that I can run on my Dell Rugged laptop running windows XP, just want to take a look at why I am having the rough idle, and maybe check my AHC system. I bought a version of Tech Stream and OBDII cable off amazon but I can not seem to make it work. Any suggestions would be helpful, or a link where someone bought the setup and it work. Thank you.
posting some details on "cannot make it work" will be helpful. What is that you cannot make it work?
Does the cable/dongle light up when connected to USB port of computer? (most dongles have that light to show they are powered through USB 5v)
Did you use the patch on techstream and invoke techstream via patch so it runs without the factory key? Tell us where you are stuck so we can give you ideas.
