Tech Questions Here (12 Viewers)
ill get it , wee needd get this for back on the right track haha , sooooooo i shure hop the temp iss coooooollllll for ark and no rain! we have had enugh my yard looks liek a swamp!
Mike, is there any chance your mic is open? That's the only thing that makes sense to me.
while we are on the subject of CBs does anyone have a tuner that they can bring to the meeting sunday, i have a old CB that i cant get anything on either and im pretty sure that after 15-20 years of being in storage it needs to be tuned. that is if it can be tuned.
No, it`s close there Brian. It has me puzzle. If it was open you will not hear your self.
I can't seem to see clearly if you have to give them your stuff and then they put it together or what? and it also says core does that mean i have to give them my axels or what? but i see that their both pretty close in comparison but the link you showed me seems like they do everything for you, you just have to put it together
You should call them, from reading it looks like they send you the front axle housing already cut and turned and you send them your housing as a core. Less down time. The rear is easy finding your driveshaft angle and welding the perches into place. It sounds like a good way to go for the price compared to the other kit you found. I'm sure you get a core charge and they re credit you once they receive yours. My .2
I'll take the .2 any day, most of the time and if it applies heh, i ment to call them today but the weather had my yards all screwed up, i think that might be beter if its like you say but the shipping might be a little steep
My battery had been looking like crap on top with corrosion on both poles. A few weeks ago I ran the battery down while playing music and accidentally leaving the lights on for too long after UL's first game and it took a jump and a little longer than usual hooked up to my buddies truck to maintain a charge/power for me to get home that night. This morning I bought a new battery, went to work, thought nothing of the battery until a little while ago when I went outside to look at it (why, I have no idea, I just had a feeling) and the poles are all wet and corroded. Any ideas about what's wrong?
My battery had been looking like **** on top with corrosion on both poles. A few weeks ago I ran the battery down while playing music and accidentally leaving the lights on for too long after UL's first game and it took a jump and a little longer than usual hooked up to my buddies truck to maintain a charge/power for me to get home that night. This morning I bought a new battery, went to work, thought nothing of the battery until a little while ago when I went outside to look at it (why, I have no idea, I just had a feeling) and the poles are all wet and corroded. Any ideas about what's wrong?
Let me guess Marty,your battery is Duralast, mind battery did the same thing. Did you put battery terminal & cable protector on your post. It works only 6 month our so:eek:
NFG battery leaking vapor around the posts.
will that all depends if you think N stands for no & G stands for good & you have a fertile mind to decipher the F the you got it!
i worked at autozone and hated the duralast batteries, i always use everlast from walmart and have never had one single problem with them.
of course if you want a really good battery go with the really expensive optima's.
