TDC is at beginning or end of CS?
Pull the valve cover and make sure your valves are adjusted properly.
It'll be way easier to start knowing things are set properly.
This is a new-build motor I removed the original and had a machine shop rebuild it, they also put on the head and did the valves. In order to adjust valve or push rod, does piston need to be in a specific position of stroke? I do have the valve cover off.
I have a FSM , I'm looking at section EM-31 now. I guess I'm gonna try adjusting the second or intake valve to see if it frees up the rocker any.
Check out EM-10
If I am following or understanding EM-10 correctly wouldn't I fist need to have the engine actually start and run first??
Is it relative or not , that when I attached the drive plate I may not have put it in the exact orientation that is was in before removing? Would this affect the placement of the marker pin and marks on the drive plate.
It appears that I couldn't really attach the drive plate incorrectly in terms of its rotative position. I believe there is a positioning post that I would have had to line up in order to fasten it to the crank flange.
Is there something I'm missing, or maybe im looking in the wrong direction.
Here are the specific steps I'm taking. And the end result.
I remove distributor, remove spark plug at cylinder 1, set my TDC device in to plug hole, set up a flashlight pointed at the drive plate to better see the indicator dots. I see one large dot milled into the driveplate followed by two small dots, also milled into the drive plate.
Then I begin turning the crank looking for the indication of compression in cylinder 1. Once I see any compression begin to develop I then start to look at the driveplate for the approaching milled dots.
Once the timing pointer is pointed at the two small dots, I then set the distributor with rotor oriented as seen in the FSM , install cap. I then put back spark plug, all wires, and try to start. It fires but will not stay running, if I mess with the accelerator pedal it does not make anything better.
I could really use any help from anyone who may see what I'm missing. Thank you.
I've heard of 1 person who adjusts valves with the engine running & 1 with valves cold. Everyone else runs the engine to operating temp then does the adjustment. Adjust them cold. They should be very close to correct.
Here's a picture of the timing mark. It's the line, not the ball bearing. I found it easiest to remove the clutch inspection cover, jack up a rear wheel, and rotate the flywheel by hand. I also painted the line yellow to make it visible with the engine running.
