Good morning all,
I resealed a transfer case with OEM seals and installed new output bearings about a year ago. It seems to have a very slow leak. I need some advice! ‘97 LX450.
I cleaned everything/added UV dye to the tcase, and it’s definitely Tcase oil leaking from between the transmission/transfer case, so the assumption is a bad input shaft seal.
When I rebuild the Tcase, I noticed a visible groove on the sealing surface, but it didn’t seem deep enough to cause an issue. The seal was definitely install straight and pre-lubed with oil.
I’m removing the powertrain in November/December anyways and would like to take care of this while it’s out. Would you guys just try putting in a new seal? Speedi sleeve? New input shaft? (Amayama shows the shaft available for $140)
Just trying to avoid doing this job more times than I have to!
