- Thread starter
- #101
Heres a List of what it took to do this motor and trans aside if anyone else is ever intersted in a swap. I paid $325 for a complete tbi and ecm no harness and 107k miles. The tranny is a built 4l60e.
1. Adaptor from advanced adaptors with built in vss and motor mounts about $900.
2. Wiring harness from FuelInjectionConnection.com $325 shipped. Overall I was very happy with the harness. There were 2 wires going in to a wrong location I had to track down but other than that it was great. one was a wire into the ecm to tell the computer how fast it was going, it was in a wrong slot and told the ecm I was going double the speed. The other was the heated o2 sensor wire was plugged in the wrong slot in the fuse bank making it run all the time and killing the battery. After solving these it worked great long enough to go under the front seat and reach all the sensors very happy made the project alot easier and I have the comfort of knowing all the wiring is new.
3. Fuel Pump filters and fittings. $225 from aztpi.com. They actually are local here but ship all over the place. Its a Walbro GSL395. Works great its inline and pretty easy to hook up.
4. Exhaust. $220 I made my own, I was quoted $475 for single. 2 2 1/4 from the manifolds to a 3 inch y to a 3 inch cat 3 inch out into a 3 inch inlet on a dual out flowmaster knockoff muffler. Then its dual 2 1/2s out behind the each rear tire in between the leaf and frame. Works good sounds awesome.
5. B&M Sport Shifter $180 fits nice looks cool and works great with the 4l60e.
6. A/C and Power steering lines. $120 made locally at a hose shop.
7. High pressure fuel line and other fuel line about $100-120.
8. Radiator hoses $85
9. Nuts bolts self tapping screws $100.
10. Crossmember, I made it $ 50.
11. Tank of welding gas $ 28
12. The engine was in pretty good shape but I resealed the intake rear main and fuel injector pod $60 .
13. I replaced all the sensors while is was at it $150.
14. I also had the injectors rebuilt and balanced $60.
15. Temp gauge $30
16. Wire $50
17. This is pretty optional but I had the alternator rebuilt as a 1 wire alternator for simplicity. that was $70
Thats $2773 Plus motor and trans. Altogether I spent $3500. Its a very simple motor and simple fuel injection setup comparativly which is one of the reasons I picked it. With my driving habbits in town I get 13.7-15 and highway 75-80mph 16-17. With the 2f I got about 10-11 all around. This is with 35s.
Its drives great starts everytime, does 75-80 up the mountains here. I defiantly could use some lower gears though as I'm stock gears with 35 inch tires. I'll probably just go with some 4.11s out of a 62 when the brakes need done or knuckles need rebuilt next time.
15. Temp gauge $30
16. Wire $50
I'm right beetween my 62 v8 swap to, also bought the kit and engine mounts from AA, but i went with the 350 700r combo
... progress is slow now is up to the "Oh cr@p where do i put this friggin engine now
" stage...
