- Thread starter
- #1,941
Because getting sidetracked on a project is a way of life for me I’m looking at changing up the battery system in the Target Carrier right now. Any of you guys looked into Lithium batteries?
Before this year’s camping season I would like to get an ARB fridge and if I run my engine/cab heater all night I’m already up against the limit of my battery power, I currently two group 34/78 AGM batteries at 68AH but like all lead batteries I only get about half of that before I damage the batteries (if I understand what I’m reading correctly).
From what I understand lithium batteries are often able to deliver up to about 95% of their capacity without a significant change in voltage making them better suited for what I plan to use them for in my system.
This is what I’m currently leaning towards, 100Ah, 3.2V, 2C, CA100FI, CALB EV Lithium LiFePO4 battery.
Dimensions(L*W*H): 5.6” * 2.6” * 8.4”
Four of them would give me 100AH at 12Volts to power camping accessories only weigh 30 lbs. and I believe if I wire them in the non-standard buss bar configuration I would have a battery 22.5” Long, 2.6” Wide, 8.6” High and could possibly fit them behind the rear cargo panels.
The batteries are available at several U.S sources but this is the best price I’ve found.
US $436.8 22% OFF|4Pcs 3.2v 100ah Lifepo4 battery 12v100AH Lithium iron phosphate cell batteries NEW CALB ca100 Plastic for solar RV pack to 24V on AliExpress
The batteries will need a BMS, this one doesn’t have a low temp feature but has a nice enclosure.
US $55.25 15% OFF|Daly 12V LiFePO4 BMS 4S 80A/100A Battery Protection Board 18650 Charger PCB BMS For Drill Motor 16.8V standard/Enhance/Balance-in Battery Accessories from Consumer Electronics on AliExpress
This one has a low temp cutout but I would need to build an enclosure.
US $7.65 11% OFF|DYKB smart BMS 4S 12V 60A 80A 100A 120A Li ion LifePo4 Lithium Protection Board balance High Current Bluetooth APP software GPRS on AliExpress
Just throwing this out to see if any of you have looked in to these and have any thoughts.
