Tacoma wheels (17”) on a 2022 Tundra?
Halifax, Nova Scotia Canada
Family member wants to mount TRD Tacoma wheels on his 2022 Tundra for winter wheels. The trouble is, the Tacoma uses M12 x 1.5 flanged lugs, while the Tundra uses M14 x 1.5 flanged lugs. The 17s will just clear the calipers, so that is not an issue, and the bolt pattern is he same.
Any ideas on how to mount these up? M14 x 1.5 lug with a narrower bore? Is there such a thing? Drill out the wheel to take the larger bore lug?
Any thoughts are welcome.
I dont think you have to drill anything. I tested the wheels from the Gx on the new Tundra before I decided what offset is best for the 2022 Tundra. The only thing you may have to get a spacer for the hub.
When I got the Method 703 for the 2022 Tundra, the guy told me that they are using the same wheel for both trucks. On the Tundra they used a small ring to make up for the smaller hub diameter. Very important to buy the right lugnuts
