Tach and speedo quit working 98 2.7 (1 Viewer)
pardion
Camino, California
I’m having trouble finding the correct way to fix this. 1998 Tacoma 2.7 auto 4WD
Tachometer and speedometer needles started bouncing around irratically then quit working, the odometer flashed a bit then quit. The overdrive switch does not work, everything else works fine.
I can not find a blown fuse or loose connection.
No check engine light or thrown codes.
Any ideas on what to check?
Thank’s John
looks like tach and speedo share a ground, but thats about it. have you pulled the cluster to check for damage or loose connections?
No I have not pulled the cluster yet.
Yes it sounds like a ground issue.
I need to crawl all over it and check connections.
Thanks for replying!
And your suggestion.
Tis the season for bad car batteries. You jumped anyone, or been jumped, recently?
