[quote author=cruiserdan link=board=2;threadid=17265;start=msg167795#msg167795 date=1086191797]
If I understand the mounting correctly, are the same bolts that mount the fairlead the ones that mount the winch? If that is the case, are you concered about how securely the winch is mounted with that big "plastic bushing" in the middle?
[/quote]
when you're pulling, you are pulling against the face though, right? So the "big plastic bushing" has very little load on it...
bk
[/quote]
bk
Anyone have experience using this stuff in sliders?
I don't have a winch, so I'm not sure if you have space behind the bumper for nuts and access with a tool. If you can't get a tool in there maybe you can make a nut plate, a plate with threaded holes, makes it much easier to assemble stuff like this. 1/2" or 3/4" UHMW should be plenty thick if you support it well with screws.
