I made some sway bar discos for the front of my 60, now I'm wondering what any of you guys do to hold the bar in place while its diconnected?
I have seen others use rubber bungie straps
I've heard of guys disconnecting only one side. Pretty much takes it out of play without worrying about it flopping around. Somebody probably has a better idea though....
Butt
Look at the JKS disconnects for Jeeps- they have round-headed stubs that you mount on the fenderwell area (or where ever fits). Their disconnects flip up and collapse, then you just hang the end on the stub thing, put in a big retainer clip and you're done.
Disconnecting the sway bar is over rated and usually a pitiful excuse for not having locking diffs. The whole point of them is to offer less limited axle articulation, which should keep tires planted on the ground (and prevent wheel spin). If you have lockers, you can have a wheel in the air and it's not going to spin. There's a limit to their effectiveness.
What I would do too.Chuck and Kling have the idea if you intend to keep the sway.
i find it hard to believe all the posts above reccommend not using a sway bar.......... are the advantages so small that most of you don't bother?
No need to secure the disconnected swaybar. I have quick disconnects on my 4Runner (see below). You do not need to secure the swaybar as it is held pretty firmly by the bushings- it doesn't just bounce around. The rubber bushings actually twist up when the swaybar flexes- its not just loosely held in place.
