re_guderian said:I drove with a snapped front ASB, and a Cruiser full of Scouts and camping gear. It was downright scary on twisty gravel roads.
2000UZJ said:Please explain, I'm about to run 3 days in the mountains. I removed front and rear...and ended up with a huge amount of travel, but I can see how it will be a little worse.
Would it have rolled? Likely not, but it sure felt out-of-control. Look at it this way, people diss the OEM shocks because of excessive body roll, and go to Billstiens for the firmer, sportier ride. Disconnected ASB is the anti-Bilstien. It makes worn out OEM shocks feel like Billstiens. For reference, I am running old OEM t-bars, and new OEM shocks. I used to run OME t-bars and shocks...FWIW after taking a long hard look at the geometry of the front end I'm pretty much convinced that lifting by anything more than an inch is going to cause the front bars to bind, especially wheeling where large wheel travel is expected. Ideally, dropping the ASB mounts about the same distance as you raise the truck would be s good guide. Someone posted a simple angle iron ASB mount that is welded onto the frame member. Its easy to see how that idea would work as a simple way to drop the ASB mounts.
