- Thread starter
- #21
Hmmm this might. Be a good option. What material is the visor covered in?I finally replace my drivers side visor last week and wish I did it a year and a half ago when my original final gave up the ghost. So worth the $75.
I found the super magnet thread once and can't seen to again, can you post a link?
YES! that's it, I need to do that! thanks jblaze!Is this the one you were looking for? I had it bookmarked on my to-do list.
See my post on this thread. Should have the info you need. Rosen aircraft sunvisor to replace sagging visor?Which model and where do I order the Rosens? Thanks!
I recently opened up a visor on my truck during my interior remodel. The inside (backside of the felt/fabric outer) is plastic...which you'll be able to feel now that your thinking about it. I would say they could handle a rough cleaning without worrying about water soaking thru (had I known that before tearing off the fabric of one - thinking it would be easy to replace, which its not, by the way - I would have scrubbed them hard w/ soap and water to try and salvage them). Also, the inner foam/pad that gives it its shape appeared to be closed-cell as well (or maybe after 22 years the open cell foam aged to closed cell thru photosynthesis or whatever), so water shouldn't hurt it in any way if you somehow got thru to it (which could only happen thru a seam tear or something)...although I'm a few years late on this question, hopefully it helps another down the road who stumbles upon this thread via search.Speaking about dirty sunvisors .. best method to clean then without destroy them .?
