This is a VERY painful post to write. I've been wrenching at an admittedly low yet constant level for decades; oil/filter/fluid changes, belts, hoses, plugs/caps/wires, coils, water pumps, alternators, suspension work, some fuel line/intake and exhaust manifold work on old Volvos and VWs, and assisted in a full rebuild (pistons/rings/bearings) on an '82 Rabbit. I can follow directions, but am not a great problem solver/diagnostician and engines and transmissions scare me; basically, your average backyard mechanic who knows just enough to get in trouble once in a while.
A few days ago, I swapped the fluid on the AHC. Went great, felt like a million bucks.
A week or two before that, I tore the entire interior apart almost to try and fix the CD/DVD changer and repair the rotted rear sub. Successful on all counts, and didn't even break a single trim clip.
Sooo.. today, I figured I'd do something easy and change the front and rear diff and transfer case fluids.
Rear went fine.
Even though the undercarriage of our '05 LX470 is in great shape and as rust-free as I've seen on any car of the vintage, I discovered that the @#$@#$ bolts and fasteners are in much worse shape than the metal they're attached to. Got all eight off the front plastic guard, but discovered that a previous mechanic/owner had broken one of the tabs of the guard itself. No biggie.. can be glued/stiffened. Even with a lot of experience wrenching rusty cars, two of the three bolts holding the metal transfer case guard fooled me. They broke loose fine, and were almost all the way out, when the very tips broke off. Oh well.. the guard's off, the fluid's changed, and I've got the broken stubs drilled for later fun w/ EZOuts. I can live with that.
Here's where everything went major wrong, and it's all because I'm a stupid, blithering, @#$@#$ idiot. Front diff. Everything drained, ready to go. Put the drain plug back in.. the one with the magnet. Thing is, my mind was thinking about something else and for reasons only known to those dumber than I (should such creatures actually exist), I decided that the proper place for the drain plug (with the magnet) was the fill hole. You know.. first off, first on... right? (I know... never... but hey... if you're gonna be stupid, might as well be REALLY stupid). Threaded in fine, snugged it down by hand, got out the torque wrench ('cause I wanna do everything right, right?), set it for 35 fp, and started gently cranking. Gee... seems to be taking a lot of turns.. not getting snug fast, but lots of drag... back it out a few turns just to make sure... yep, it's threaded correctly.. probably just the crush washer doing its thing..keep going... well, sure feels tight now, but the wrench hasn't registeredd 35 fp yet... well, it's a cheap Harbor Freight wrench... that's good enough, better stop.
Then, next step..fill the diff w/ nice clean awesome Royal Purple 75W90 MaxGear... wait.. can't fill it.. fill hole's plugged!! Drain is open!!!!!
Ok.. we all make mistakes.. I won't tell anyone.. just get that drain plug outta the fill hole, and all will be fine. Anyone see where this going?
Just in case the obvious ain't obvious enough, the magnet in the plug was what was causing the premature resistance.. 'twas wedging itself in the netherworlds of the diff. When I took the drain plug out of the fill hole, the magnet was MIA. Careful probing with my pinky located it, and an unfolded paper clip confirmed the location by magnetic clues, but no amount of fiddling w/ the paper clip, dental picks, my pinky, or gentle encouraging garage vocabulary over a period of a few hours was able to dislodge it. It is now safe and sound inside my front diff.
Sooooo... now what? I don't have the skills (at least, not to my knowledge) to figure out how to remove and open the differential. I can't drive the car.. heck, I'm afraid to have it towed thinking that any motion will cause that magnet to eat my front diff.
Feel free to hurl insults, epithets, and cast aspersions re/ my non-human genetic makeup. I've already done that.. so you might as well join in. Afterwards, if anyone has any ideas how to salvage this incredibly ridiculous self-inflicted situation, PLEASE speak up.
Gotta give me points for originality... pretty sure this hasn't been done before.
Rear went fine.
Let us know how you end up getting it out (because you will be able to get it out).
