My first mechanically necessary job was a success...changing rear brake pads.
I used toyota OEM pads and reused the clips and shims, they seem fine and no squeaks so i declare success.
However...
My PS rear inner pad was worn way down, significantly more than the others, the others were probably 1/3 pad left while the PS rear inner was pretty much gone. I'm guessing maybe it was rubbing and maybe thats why my MPG has been less than what I think it should be?
I'm attributing this to the top slider pin being stuck pretty good in there...a lot of brake cleaner and twisting and pulling finally got it out. There was a light coat of rust on the pin...
I cleaned out the hole with brake cleaner and q tips and cleaned the pin really well but I don't think theres any way to really get rid of all traces of the rust. I greased it up and put it all back but..
Do I need to change the caliper? Pin? Any advice on this would be appreciated. Thanks guys
However...
