Structural Question About My Roofrack
Orlando, Florida
I am in the process of designing a simple roofrack that my 2 kids (20 & 18) can weld up as a project. The rack will never need to hold a rooftop tent or anything particularly heavy but obviously needs to be sturdy enough if one or both kids do some star watching or what ever.
The overall dimensions will be 90" x 50" (Full size rack) and I plan to use 6 Gamiviti gutter mounts.
For simplicity I was planning on using mild steel square tube for the main frame. I was going to go with 1" x 1" x .095". Each corner would sit on a 4" x 4" plate to keep things square and solid at the corners.
For the cross rails I was planning on using Tee bar (1" x 1" x 0.125"). These would be spaced out every 10".
Would very much appreciate if someone with fabrication experience can chime in and let me know if the tube and teebar is sturdy enough. Also are 6 gutter mounts sufficient.
Thanks in advance.
I’m just passing through and clicked because your username and I’m drinking Irish Whiskey.
Sounds heavy as hell. That’s some thick tee bar.
Wouldn’t that be harder to weld than just squares?
Is there any popular branded rack you can sort of “copy”? I don’t even know what section I’m in here but those thoughts came to mind.
Weight is a concern but having never designed something like this before it is hard for me to get my head around the weight vs structurally sound dynamic.
Hope you have a good whiskey. My local ABC was selling a 12 yr old Bushmills single malt for $39. I added a few to my rainy day stash.:D
I had one of those big, heavy, full-size Con-fer racks for a while. Think it had 4 mounts on each side...
When I was running load calculations for my roof rack I came up with 1”x1.5”x0.065” wall rectangular tubing for my crosspieces. You can look up a beam deflection calculator online to see how much your crosspieces will deflect under various loads.
I’d recommend going with 8 gutter mounts for that size rack, though if you’re never going to put a lot of weight up there then 6 would probably do.
Wasn't a gutter mount, but I built this for going to Baja with Locos Mocos in 2001:
That is 1.25" square x .065 tube. It has one cross-bar and the perimeter frame. The supporting feet are 1.25 X 2.0 X .065 and the hinges welded to the bottom of the feet were screwed to the roof structure of the Suburban. I hauled all sorts of stuff on it and have parked my heavier than I'd like carcass up there in a camp chair to watch for incoming race cars. The deck is 1/2" outdoor rated plywood screwed to tabs around the inside of the frame. I mitered the corners and left gaps there for rope tie-down access. Original plan was two 1/4" thick plywood panels underneath to make a fairly smooth and flat top and bottom (aero), but ran out of time to get those painted and they never got installed. Included in the rear frame cross-member were threaded inserts for an air deflector to push some air down the back window to help keep it clear of dust. I had just started that part when we had to leave for the team meeting, so it too never got installed.
It did flex a little when I walked around on it, but not enough for me to worry about it.
Thanks guys for the feedback. I fed the dimensions of everything into Grok and it came back with various calculations for strength and beam deflection for the tee bar on the cross rails. It was able to estimate the weight (69lbs) along with advising to increase the number of gutter mounts from 6 to 8. All in all I am plenty happy with the design so time to get welding.:)
I am building this very rack now, in the fashion of an 85x54 Confer rack. I am using 1x1x16ga square metal tubing. I don't know how heavy it currently is, but i was able to put it on top of the rig by myself. i am planning on using four (4) gutter mounts on each side. I am still researching gutter mounts myself.
