With my 80 and my 100, if I connected the SG while the truck was off, it would pull power but would not move past "connecting", since there is no data coming from the port and ECU. Even after starting the truck it wouldn't pick up the data signal. If I connected it after the truck was running, it would cycle on and off just fine. Two different trucks, two different SG units.
Perhaps a difference in SG firmware.
Or maybe a setting within the unit? Probably worth a call if you're into getting it corrected, they seemed more than willing to help.
And sorry for the slight hijack Rob, but hey I guess we're adding a little value here after all.. my goal is to have this always plugged in, no re-connecting required.
I'm not saying you have to reconnect it each time, just the initial connection. With mine at least if I connected it before the truck was on, it would stay in "connecting". If I hooked it up once the truck was running it would connect to the data feed and then I could turn the truck on and off without issue.
Looking forward to my new circuit board!
