Stock wheels max functional tire size (1 Viewer)
If I leave my 200 stock, what is the largest widest tire I can run on the factory 18 inch wheels? I have a set of sequoia 20 for street. These will be an off road set.
What did you find out 275/70/18 ?
305's or even 315 could fit..... depends on if you're willing to use spacers to clear the KDSS.
295's are the safe play otherwise.
I easily run 305/55/20s on mine, or 33x12.5". With just a little bit of plastic trimming. Equivelent in an 18" tire would be 305/65/18.
Only thing as mentioned above is the have the right wheel offset, or wheel spacer for the right effective wheel offset if using stock wheels. You'll want to be in the 30-40mm offset range. Or a ~1" spacer for the stock 60mm offset wheel.
