I use 20w-50. But I like to do half synthetic and half regular oil. I don't know if it makes that much of a difference as long as you change the oil regularly.
FJTOYMAN said:What do the oil numbers really mean. 20w-50 vs 10w-30 and why is 15w-40 considered a diesel oil?
FJTOYMAN said:This maybe old news but I use 10w-30. Most of the time I was buying it by the 12qt case. The other day I was in Autozone and found 10w-30 in gallon jugs. I like those better. Makes it easier to recycle.
Stupid Question. What do the oil numbers really mean. 20w-50 vs 10w-30 and why is 15w-40 considered a diesel oil?
LowcountryTLC said:What about shifting over to synthetic? I've heard if the engine has run previously on regular, going to synthetic will basically "bleed out" the engine seals. True?
10W-30 seems a bit thin for these engines unless you're in subzero temps etc. 15W-40 might be nice...I just switched my mini truck from 10W-30 to 5W-40 and the valve tap noise MAY be a LITTLE quieter, and the hot-start death rattle noise has definitely quieted down. BTW, I compared the 10W-30 to the 5W-40 in identcal clear containers at room temp, and the 10W-30 seemed REALLY thin and watery next to the 5W-40(both syn.)FJTOYMAN said:My valves make a horrible ticking sound...Would running an oil other than 10w-30 help?
