Stock 16" wheels interfering with Icon suspension... help please
California
If this topic has been covered before I apologize. I did my best to do all the research I could before buying parts but the last time I asked for help here I got blasted by other members for asking things that have been asked before. Due to that prior experience, I perhaps wasn't as informed as I wished to be (although I thought the stock wheels would work because that's what most people seem to be running) before spending my hard earned dollars on parts. I'm hoping now that I haven't wasted money on wheels and tires that are not compatible with my new suspension setup.
So here's the problem! I just lifted my 99' LC 2.5" with a package consisting of Slee Diff Drop, Nitro Gear UCA's, OME torsions and springs and Icon remote reservoir shocks. Prior to the lift and for many years, the truck has been running 18" Momo wheels and last winter I put 285/65-18's which are 32.6" tall. After the lift, the truck seems to have no problems with this combo and I even trail tested it, it seems fine. However, I do not want to run 18" wheels anymore and so I bought a full set of stock 16" wheels, powdercoated them black and mounted up 295/75-16's on them, which are 33.4" tall.
Upon mounting them at my local tire shop, the tech stopped because there was going to be interference issues. With the suspension in full droop, the UCA's seemed dangerously close to the tires in the front. In the rear, the remote reservoirs were going to interfere with the inside of the tires too. In fact, with the suspension hanging the rear end was askew and not centered under the truck. Is that normal?
So now I am back to the drawing board, trying to figure out how to make all this work. Although I am hoping I didn't just waste money on these wheels, I will buy something else if that's the only option. I really wish someone with the knowledge here would make a comprehensive list of 16" aftermarket wheels that are known to work on lifted 100's with large tires but all my searches yielded nothing. Should I run wheel spacers? Should I relocate the remote reservoirs in the rear? I'm pretty sure Icon had me mount them there for a reason? I appreciate all helpful thoughts, ideas and solutions.
Here are a couple photos to help you see what I am dealing with. Unfortunately, they were taken with the 18" wheels and the truck on the ground. I was kind of rushed when at the tire shop so I didn't think to take any photos when the truck had on the 16's and was on the lift.
tire-suspension-issue.45003
tire-suspension-issue.45002
Others have moved the rear reservoirs to the lateral crossmember above the rear axle.
That reservoir location in the front has worked for other here--as far as I know. Obviously everything looks fine in the photo you've shared. How close is is "dangerously close" with your 295/75-16's?
I'm running the same size tires with the Nitro UCAs, and I've got about an inch of clearnance with the truck sitting on the ground.
I wouldn't run the reservoirs right there in the rear myself. The fronts are not bad at all. When I had that size tire on 16" factory wheels with stock uca's I had maybe 3/4" of clearance at normal street pressure and never had a problem, even with air pressure in 15 to 20 psi while on trails no problem.
Thanks guys for the input! Yeah, I think I'm going to start with relocating the rear reservoirs then see where I'm at. To answer your question Hayes, from what I recall the UCA's were about 1/4" from the 295/75-16's on stock wheels, when drooped out on a lift.
IIRC there is only about 1/2" between my tire and upper ball joint running stock 16" wheels. Definitely not enough room to run snow chains.
Slee sells spacers that are very popular for lifted 100's and would give you your clearance back. I do think you'll be ok without if you relocate the rear reservoirs.
Kudos for going to a 16" wheel to get more sidewall.
I've got the same size tires/wheels, same shocks, but TC upper arms.
Never had any issue.
I am now running the Spidertrax spacers up front.....originally to make room for chains, but I liked the better stance, so they stayed.
Stupid location for rear remotes...time to find a different installer
We'll have to see if anyone else weighs in on this clearance. I'm not sure what is considered adequate, but I'd bet that it's OK.
Sorry it took me so long to give an update here. Just to give some closure to the topic and help anyone else doing a similar install, I was finally able to get the wheels/tires to fit properly. The first problem was that the rear remote reservoirs were indeed mounted in the wrong location. I had the shop that did the lift correct this and then the clearance was fine in the rear. However, there still was not enough room up front. I finally ended up installing a set a wheel spacers (1.5" front, 1.25" rear) and all problems are now gone. The stance looks just right and the wheels do not stick out of the fenders. I am happy now :)
