New-to-me 2003. Great condition truck but the steering is very heavy and stiff. I wouldn't call it "binding" like some of the posts I've read, however. It's the same resistance all the way to the left and all the way to the right. Steering is tight with regards to not having warn-out components but just hard to turn. It tracks well down the highway but any little steering adjustment you need to make takes a lot of effort. Definitely not able to thumb it down the road. I can't imagine this is normal operation. I've had a lot of vehicles in my life and have never encountered steering this heavy.
Run down of the usual suspects:
*New tires and alignment 3 weeks ago
*No whining noise from the steering pump, etc.
*New poly steering rack bushings recently installed but was stiff even before these were installed.
*Power steering fluid is dirty but full.
*RACK AND PINION LEAKING/WEEPING FROM BOTH SIDES
***I'm tempted to throw in a new rack but would not think a leaking rack would be the root cause of heavy steering unless it was a massive leak? I'm inclined to have the power steering pump pressures tested first.***
Thoughts?
I'm all ears. If budget wasn't a problem, what is the reasonable course of action? We plan on using this vehicle heavily for our adventures and want it to be a smooth operator. It's been great with the exception of the steering. I'm likely to do the work myself but also have access to a good shop.
Thanks!
Thoughts?
Thanks!
