stereo time
sittin on the couch in UT
im installing a stereo and some speakers, i hooked it up last night and it worked beautifully. im wondering though if i should hook it up the the ignition or the fuse box, as it is now is on all the time, so i take the face off, but i want to hook it up to the acc position in the ignition so the key has to be turned to the first notch hen it gets power, what color of wire do i need to tie into? or what fuse on the fuse box. thanks
My system has two power lines. One that is hot all the time for the clock and settings and one that is controlled by the ignition switch to turn on the unit. It does have an over ride feature that allows you to turn on the radio if you hold the on button for 5-10 seconds and will play for 20 minutes then turn off automatically.
mine has 2 powers as well, one staright to the battery for memory (clock, stations etc.) but the other one is the one i need to hook up to the ignition so it turns off when i turn the cruzer off.
evens where does your power wires go too?
come on troll im lazy you know that. i just want someone to tell me ;)
the wire diagram for the 76 fj40 shows it coming off the wiper fuse the wire color is "L" I guess Lavendar. It is the one that goes to the Windshield wiper motor. That would turn off and on with the key.
Thats for the stock radio so i'm guessing no memory. Use one from the battery to keep your memory on the always on wire.
thats what im talking about. ill tear into it tonight and keep you posted
CC,
My 77' FJ40 had some creative wiring done by the PO which I fixed a few months ago. There was an Alarms system, Stereo, CB Radio, Sound Bar, Spot Lights, & driving lights that were all spliced in at different places. The wire diagrams in the haynes book for the 77' and 76' are the same for the parts we are talking about.
I added a new fuse block with four circuits (pretty cheap at local auto parts store). For switched power I spliced into the BY (Black with Yellow stripe) which you can find coming out of the steering cloumn. However this requires the Key to be in the run position to get power. The wire you would want is LR (Light Purple and Red) which supplies power when the key is in the ACC position. You should be able to find that coming from the steering column as well. That is the same wire that goes to the fuse block and feeds the wiper motor fuse which is the L (light purple) wire that Wes mentioned.
Anyway, I recomend adding some new circuits to avoid future electrical problems which can be a pain to troubleshoot.
Good luck.
CC,
Good luck.
no worries, i plan on hooking it up to the acc wire, i have a couple fuse boxes and my wirings not to bad.
They both go to the fuse panel. One to a constant power fuse and the other to a fuse controlled by the key.
Ahh I'm lazy too. That why I just used a multimeter and switched the key to the first position and worked my way up the fues panel till I found one that worked. I originally had it second from the bottom but it only came on in the second potsition of the key which meant I had power running to the coil. The only one I found that acctually worked in the first position was pretty close to the top.
A little trick is to put a spade connector on the end of your wire and bend the spad in the form of a J. Pull one end of the round fuse and slip the J part underneath and push the fuse back in. Works pretty good. Also one side of the fuse holder is a direct link to power while the other is to the accessory. I always put the J on this side so the fuse acts as a seconday fuse backup.
Trollhole said:
Ahh I'm lazy too.
i have been using that ol trick for years , my dad used to do i as well. fantastic
don't you have one of those nifty fuse block covers that tells what fuse is 2nd from the bottom or pretty close to the top? :)
Hell, I thought everyone did this..... :) - you would laugh if you saw my fuse box I suspect....
Trollhole said:
I don't think they had them for 76 40's could be wrong I have never seen one. Early cruiser had them
yep, SOR has (had) them. I got one - original used - for like $15. they list a 9/71-9/77 fuse block cover. nice little piece of original equipment to add back if you can find one. helpful as well with knowing what fuses you are tapping into.
