stereo time
I wired mine without going through the ACC on the ignition. Means you can have it on (great for camping, etc) without needing to go look for the keys.
Hey Cam
How bout posting some pics of the stereo and speakers? There is at least a couple of us looking to do the same in the near future.
Brad
okay gotter done just in time for the weekend wheelin trip, i got it all figured out,
i have no fuse cover, should get one but lazy, i have an ammo box in the center console and i put it inside, water proof. the speakers are just in som speaker boxes not attached so i xould move them around all the crap the wife has me pack for trips, some day ill permenatly attech them.
ill get some pics, nothing fancy, i got me a 50 buck wal mart stereo and use my ipod. it works prety good.
camcruiser13 said:
and use my ipod.
I ran an audio-in cable under the dash and along the door jamb and under the seats up into the center Tuffy console so I can use my iPod (since terrestrial radio sucks so much). nice and hidden cable and iPod just sits on the Tuffy console cup holder when I want to use/access it.
in my 78 i put a $100 pioneer in a tuffy box.
the wiring was easy...found out which fused were hot with the key in acc and hot all the time.
5th fuse from the bottom is hot with the key in the acc position. just pop the fuse out on one side and slide the wire in....then push the fuse back down and it "clamps" the wire in.
my64fj40 said:
Where are you moutning your stereo and front speakers???
Still undecided of where Iam going to put mine and checking out what other people have done..
Thanks
-my64fj40
I'm no sound tech but I seem to remember that base speakers are better when mounted low down and tweeters are better as high as you can get them - top of the door linings or even better in your overhead console if you have one. Don't put 6x9's up there cos they will be wasted to a certain degree.
6x9's in the doors as low as you can is the best (IMO) but remember that you will inevitably kick them occasionally as you get in and out of the truck. I went for 6x9's that came with some heavier duty speaker covers. The normal mesh type covers won't last long if you put them in the door.
Good luck and putting in a stereo is always enjoyable but most wrenching is if you add enough :beer: :cheers:
