Hi Guys,
I installed a Kenwood DDX492 using the Scosche TA02B adapter that bypasses the factory amp (two grey plugs). I blow the fuse in the unit when I try to fire it up. Everything is wired according to specifications and the speakers all work fine with the original radio installed.
The factory amp is bypassed but I wired the blue w/ white stripe that remote turns on the factory amp. Do I need to unplug the factory amp at the right kick panel? It appears I have deleted the amp by using the two grey connectors in the Toyota harness (R1A & R3B).
The factory S11A connector was removed from my factory radio & is no longer in use. I didn't locate or disconnect the S12B connector.
Any help is much appreciated.- Ted
