I have a 4-way steering damper on my 80. I fitted it because I had read good writeups on them. I haven't been happy with it. I'm not convinced they work any better or worse than a normal stabiliser. I probably won't buy another to replace it.
The way the spring is mounted it has forced the spring to rub against the damper body and as the coil rubs over the end of the body it catches a bit.
Raventai, the spring is set up to have no tension in the centre position and either compress or extend as the steering is turned left or right. A mounting bracket kit to suit the vehicle is included.
Ats4x4dotcom, those fox dampers look good, have you got a price?
Landtank, a couple of the 4x4 hire places in Hervey Bay routinely adjust their steering stops on their troopys to reduce the angles on the birfs to try and lessen the possibility of birf failure in the hands of the backpackers. Whether this works or not I don't know but they don't usually worry that much about the castor on their rigs as the diff housings are usually bent from the backpackers jumping them!
