steering rag joint.
when snow wheeling I had a problem with my alternator.
while trying to fix it I was shocked at how hot the rag joint had gotten.
I have a header and had been running 4000 to 5000 rpm now and then.
it was WAY flexible and the steering felt a bit loose.
I have been told before to remove it for rock crawling.
when I took these pictures I notice the burned wire on my wifes truck. it crosses the rag joint. I am now wondering if that is the problem that Toyota's have with the starter not always working. the famous click click.. but nothing from the starter??
anyways.
stock rag joint set up.
there are two bolts and two studs.
I removed the bolts and beat the studs out. turned the wheel 90 degrees and bolted it back up.
the hole line right up.
I would have left the studs, but they did not bolt down tight.
so I just used the bolts.
a little bit more vibration feed back though the wheel, but not bad. Now I don't notice it at all.
the left over parts.
The wire is just to make sure the rest of the steering wheel is grounded, and I believe affects the horn. Did your horn still work before you did this mod?
i had a rag joint break on a cruiser a few years ago on a hill, and now remove them. i did the same thing you did, works well..
