Steel Seal. Head Gasket repair in a bottle?
Clearfield, UT
Found this website:http://www.steelseal.com/eng/home.html
It claims to repair cracked heads and blown head gaskets with one application. Has anyone out there ever used this product? I doubt it, as a search using "steel seal" came up with nothing. Can this be the miracle elixir, or just another serving of snake oil?
Products like that are often used by shady "buy here pay here" car lots that sell cheap junkers at very high interest rates. They often do fix the symptons for a while but it is like putting tape over a hole in a leaking bucket. Sometimes it works for a long time, sometimes it works for just a short while. I personally feel that you are just delaying a repair with the potential of causing even more damage i.e. cloged radiator, heater core etc. A friend of mine had a head gasket blow, dumped some stuff in the radiator drove around for a while then traded the car in. The dealer commented on how nice of a trad he had :D
Agree with John - I used K & W block seal in my 87 toyota 4wd (22R) pickup for a blown head gasket - has 330,000 plus miles - basically a farm truck only - works for a while then blows out again - heater core clogged too.
I wouldn't use it on a truck that I was going to keep or put on the road unless it was a emergency/temporary fix to get it back home from a trip.
If you're going to keep the LC do it right with a HG kit - just did the HG on the LC with the gasket kit from C-DAN
My old 6 series BMW had a cracked cylinder head and coolant would leak into the exhaust. If it sat for a day or two, I would get a pretty impressive white cloud out of the exhaust. For a while, I would just release the coolant pressure by cracking the cap on the expansion tank after parking then it would not leak.
I drove the car about 2 to 3K miles a year and had spent a fortune on everything else it needed so I started looking around for a "snake oil" fix. Found this stuff: http://www.jemdistributors.com/ I used their Quik Seal and for about 2 years didn't lose a drop of coolant. Drove it from Oregon to southern California for a car show at an average speed of 90 miles per hour and never had a problem.
As tempting as that product is, I would not do it again unless I had no other option or the vehicle was only for "special purposes" (read local, no highway unless in constant cell phone range).
Riley
