I've got an ARB deflator that works very well but my son suggested we buy another to speed up the air down process. I saw a few of you guys using Staun type pre-set deflation valves during the Mingus run and I'm considering getting a set.
The question I have is how does one calibrate it for 16lbs at 1500ft in the desert at 85 degrees then have it still work correctly in the mountains at 6000ft and 40 degrees? Wouldn't the pressure be off substantially given the altitude and temp changes?
Should I stick with a pair of ARBs or switch to Stauns?
