My 62 just starting having a bit of trouble when I start it. When I crank it, it turns over fine and then it stumbles like it isn't getting enough fuel. I can give it some gas to get it started, then it is good to go. Once it is running, it runs great. It started acting this way pretty recently. It seems to be getting a little worse, sometimes it doesn't start on the first try. The starter seems fine, it just doesn't start the engine.
Any ideas? I've searched around, but given the fact that it runs fine the rest of the time, I couldn't find a definitive answer. I have recently replaced the wires, plugs, and distributor cap and rotor. I have a new coil, but haven't installed it or tested the spark off of it. I will try to see if there are any codes tomorrow night.
