- Year
- 1975
- Vehicle Model
- 40 Series
- Location
- St. Augustine, Florida United States
- Mileage
- 12345
- Color
- TAN
With deep regret I have to sell my 75 Fj40 4 spd Its all apart Was driven on the highway before taken apart, every thing works fine, asking $8.800.00 CASH. Frame and axles coated w Eastwood Ceramic coating, all new brakes, calipers, brake lines, knuckles, new 2" lift springs w hardware, This is a roller, This frame is set up for a Chevy 350 motor w Advance Adapter mounts for motor and transfer case I DONOT HAVE THE 350 MOTOR it was trashed. What I have is a Chevy 4.3 V-6 200 HP w roller cam, 262 ft. lbs. low end torque the body mounts will have to be moved back 2-3`s for fitment, it still has hash marks in cylinder walls and clean in side the valves need to be lapped in and the heads are off and the valves are out, heads need to be cleaned, if u don`t want the motor I can knock off $ 750.00 The body is in really good shape The tale gate is after market w hinges There is some rust thru under the gas tank about the size of a dollar and rust thru on the back lip about 2-3"s. It has been undercoated on the back portion and is coming off for the most part it has all surface rust and some pitting. Windshield and metal doors excellent shape, gas tank still has plastic on bottom and the gas tank cover has some cancer on bottom flange 1 spot, radiator and, mount is good the bottom shroud has some rust thru. Fenders where cut to accept the headers, seats excellent shape, no headrest, heater works, has space ship heater works w an extra core w 3 hole bottom w lines, Has dash cover, the dash was trashed , roll bar w padding, grill has some rust thru on bottom and component's good shape, LED head lights, also have two alternators, new starter to go w 350 motor Have 4 springs w 4" lift on them goes w it. Knobs have been painted and cleaned, l also has a Best Top Vinyl top in black w all hardware sorry no doors, Also have a GOBI Roof Rack #GTLCFJ40R valued at $ 1,600.00 w light bar full cover from the windshield back w ladder, mounts to body, brand new never installed Ask For PICS @ buzkan@att.net
