SOLD Springfield, VA: 1970 FJ40
Year
1970
  1. 40 Series
Mileage
91000
Color
rgb(67, 63, 63)
Outside Link
https://www.ebay.com/itm/265394380516
I just listed my FJ40 on Ebay. Asking a very reasonable price to get it moving. I've owned it for 3 years after the previous owner sold it following the build. Haven't had any time to give it the attention it needs, so I think it's time to part ways.
Listing can be found here on Ebay: 1970 Toyota Land Cruiser | eBay - https://www.ebay.com/itm/265394380516
Selling Price: $24,000
Here is a cut and past of the description as well as a couple of pics.
1970 Toyota Landcruiser FJ40 has 307SBC and 4 speed manual Toyota transmission. Just about everything mechanical is less than 3 years old including nuts and bolts. A complete rebuild.
Vehicle is currently registered and inspected in the state of Virginia.
Engine/Transmission
307 CID small block Chevy/Toyota Land Cruiser 4 speed manual Transmission and transfer case.
Below is a list of new parts included as part of the build. Everything you see was installed has less than 2000 miles since the rebuild in 2018.
Edelbrock intake, carburetor (650 cfm), fuel rail, air cleaner, and valve covers.
Holly fuel regulator, fuel pump, battery, hoses, thermostat, fuel line, fuel filters, alternator, starter, water pump, timing chain and cover, oil pump, belts, oil pan, pulleys, fan, headers, forty series flow master 2 1/2" exhaust, all new fluids, wires, plugs, distributor, coil, fuel sending unit, oil pressure sending unit and switch, pilot bushing, throw out bearing, Advanced Adapters conversion kit and mounts, center force clutch and pressure plate, slave cylinder, clutch fork and pivot ball, spring, clutch master cylinder, speedometer cable, and accelerator cable.
Brakes
Brake booster, master cylinder, steel lines, stainless steel soft lines, shoes, wheel cylinders, springs, brake pressure switches, and new fluid.
Accessories
All new lights including, headlights, front directionals, rear backup lights, tail lights, plate light, large LED light bar, small LED spot lights, LED strip lights under the dash, interior courtesy light, and new gauge cluster bulbs
Hi Lift jack and bumper mount, horns, relays, floor dimmer switch, turn signal switch, flasher relay, fuse blocks, windshield wipers, windshield washer and switch, vintage air heating system with defrost, oil pressure and water temperature gauges, tough duck seat covers with matching sun visor covers and back seat cover (BestTop), BestTop soft top and 2-piece doors, Smittybilt rear tire carrier with custom rack for Jerry Can, shift knobs, shifter boots, windshield mounted side mirrors, all bolts replaced with stainless or grade 5 or 8, 5 lap belt seatbelts and hardware, rear emblems, antenna, aluminum side step covers, hood bumpers, pedal pads, windshield gaskets, recovery shackles, trailer wiring kit, and Herculiner bed liner inside the tub.
Drivetrain
Shackle spring bushings, shackle pins (greasable), tie rod ends and clamps, relay rod ends and clamps, drag link, wheel bearings (front and back), steering bearings, axle seals, hub assembly gaskets, pinion seals, center arm kit, Rough Country shocks and stabilizer, Summit Racing Wheels (5), and Firestone Destination A/T 31-10.50-15 tires (5) and lug nuts.
With all of the above items, this 3 year old rebuild has over 20K in parts alone not including labor.
As part of the rebuiled, paint and filler were removed, replaced some rust (not bad) with fresh steel, added some filler to smooth (see pictures), hit it with a lacquer primer, and Rustoleum Charcoal Grey. You can clearly see the purposely left defects in the body which really makes the rig look mean!
Do your own research before you bid! Vehicle will be sold AS IS.
Buyer is responsible for shipping/pick up of this item in a timely manner!
