kcjaz
I currently have BP-51 with 2721s on the rear plus 30mm spacers. Since I installed the springs I have added a lot of weight (winch, full BB skids and a Dissent rear bumper with dual swingouts). I'm still happy with the 2721 though I think I'm at the limit weight wise. As I'm adding a 24 gal LRA in a few weeks, its time to also change the rear springs. I do not have drawers but carry a lot of stuff and will likely add drawers in the next year. So which spring to change to? I've gone back on forth on going to 2723 or 2724. I think 2724 is the right answer.
I came up with 2724 are the right spring based on calculating the compressed height at an assumed load. I don't know what my rig really weight but I'm guessing its in the 7200 lb range loaded for LCDC or something. So just dividing by 4 gives 1800 lb/wheel. I just did the simple math with the published spring rates. The 2721s are progressive so all I did was average the the two rates to calculate the deflection. The result was that either spring (with no spacers) will put me within about 1/4" (7 - 8 mm) of where I would be with the 2721. The 2724's will put me ~8mm higher based on all my assumptions. My future drawers will probably be another 200 lbs (0.5" more squat at 400 lb/in). My analysis is here:
I know I may be over analyzing this but that's what I do. Is there a flaw in my approach or math?
I can fix ride height with spacers if I need to. The thing I do not know is how 400lb/in will "feel" in terms of ride comfort vs. 340 lb/in. I think that is personal preference and the only way to tell is to try one. I would say I'm a bit "floaty" now but I haven't cranked up compression setting on the shocks. (I'm going to do that this week and see).
I can also mess with the BP-51 shock settings. Or potentially use spring rubbers. This is the part of my self inflected "do-loop" where I talk myself back to 2723s because I can "adjust" with spacers, shock settings and/or spring rubbers....
Thoughts/advice???
Thoughts/advice???
