got my 55 series springs out finally, what should i do before installing them on my 40 (pull em apart? paint? with what?)
72cruiser said:not sure where to get the new center pins from....any ideas (dealer?)
I don't see the diffenence, how many clamps do you have on there in total? That would be a good way to make your own. How will you attach it though? As long as you have one in front of the axle and one behind, I think you'll be OK as long as they are in a position to hold all the leaves alligned. You will increase the risk of breaking a spring or pinion from axle wrap though. Those clamps help prevent it. I like the ones that have a bolt through the top, they allow the pack to spread a little, but not too much. And you can take the bolt out if you want. A couple on my 45 springs had been welded on by a previous owner. Needless to say, I chucked that leaf.bad_religion_au said:i busted a spring clamp pulling them apart, and was quoted 175 dollars for a new clamp (yes that's australian funny money) so i was wondering, would it be harmful to use a bit of box section, with the top cut off (so in a U shape) with a bolt through the top, instead of the clamp (was going to open up the clamps for travel anyway.)
bad_religion_au said:i.e. the bolt will only stop gravity from making the U fall off, nothing else puts force on it in this downward direction, it should be strong enough
