just wrapped up a resto on a 40 with a 60 series drivetrain in it (2F-H55F-60 split case) and was driving it around and noticed i could not get the t-case out of low.
shifter moves through all 4 positions (2/4xH/L) and can feel it hit the detents, but clearly not coming out of low gear. cracked the case open to see what the deal was, cant find anything obvious. discussions with other cruiserheads suggest there should be a roll pin of some sort that fastens the H/L shifting actuator to the rod on which the shifting fork rides. when case was split open, i did not see a roll pin, nor did i see a hole for one.
with local guru(s) out of town on the expeditions 7 trip (bastards), i am looking for other snazzy ideas. i have a 62 series FSM to look at, but since it is vacuum shift, part of the diagram i would need isnt covered. i also did not see an obvious provision for a roll pin...
as a possibly relevant side note, it was difficult to shift from high to low and vice versa when the back of the case was off shifting the fork by hand...
any ideas?
TIA
any ideas?
TIA
