Speedometer won’t work
Check the circuit traces on the PCB in the speedometer:
Found a NOS circuit board in Florida, ordered it tonight.
Check the speedo cable connection at the transfer case. Unscrew it and slowly pull it off. There should be a small squares off pin. It could have sheared off or become rounded. The part is still available.
I have replaced this sensor and pin, 2 times. I thought my first amazon purchase seemed cheap so I went and got a higher quality unit. Same result. Thank you for replying.
Test continuity on your wiring harness. Do you have a multimeter? I'd disconnect both ends, and make sure you can get continuity through the harness. Also, check the FSM. There's a troubleshooting procedure for this I'm sure.
