Broken Speedometer Repair
Oregon
When I bought my '94, the speedometer didn't work. I did some Googling and turned up the VSS as a likely culprit. There was a good deal on NOS Toyota units on eBay, so I bought one. Didn't fix it.
I read somewhere (here or maybe Expedition Portal?) about the speedometer circuit board looking 'burnt'. Sure enough, mine did, right at the top:
I took a brass brush to it (the 'toothbrush' type) and the "burnt" stuff came right off, revealing two damaged circuits:
The left half of the top circuit was still intact, but looked really sketchy, so I did a two-step repair on that part. The speedometer works great now, though the tripmeter is still non-functional, except for the tenths digit.
I don't know what caused the circuit to fail like that. I can't imagine that it's somehow collecting moisture there. The lower circuit is really thin, so I can see how it might eventually burn out, but it still seems weird. I noticed that there are a few capacitors that look like the Nichicon ESR capacitors that are known to leak and corrode circuits. Lexus guys have found that leaking capacitors are damaging their ECUs in a similar way, but I haven't read much about that on Mud. Here's a link to the discussion on Club Lexus:
All my crazy Lexus issues SOLVED!! (ECU-leaking capacitor) - Club Lexus Forums
Hope that helps someone.
My circuitboard looks almost identical to yours, did this work?
Yep, it's been working great for months.
I recently discovered a product that would probably work great for repairing these kinds of problems without soldering: CAIG CircuitWriter. It's a conductive ink pen. $20 at Fry's.
Hah! I actually just tried that without success. Going to try doing the wire method you used.
Is there a particular type of wire you used to solder the joints together? Here's what mine looks like:
By the way, thanks for your fast response!
Update, attempted the wire solder without success. It's possible I need to make more connections or that my soldering skills are bad. Will attempt more tomorrow:
When I did mine, I put a multimeter on contacts along the various circuits checking for continuity.
And you might want to get a softer brass-bristle brush. It looks like yours was a bit harsh. :-)
I have been working through a nonoperational speedometer and odometer (cruise control works) and I'm thinking I might have a burnt path like the images above. Is this circuit board located inside the cluster?
The odometer module sits inside the cluster. There is a thread somewhere about how to remove the speedo to repair the broken gears.
