So I finally got the gear I needed for my t-case. I had a 4.11 gear in but need the 3.73 if I want an accurate reading. I ordered the 16 tooth gear from SOR to replace the 18 that was in there. Installed it and took for a drive and no movement of the needle. Hmmmm.....
After careful inspection the outside diameter of the 18 tooth gear is .825" (marked 6x18 on shaft) and the outside diameter of the 16 tooth gear is .728" (marked 6x16 on shaft).
The teeth aren't even engaging the output shaft on the t-case.
What do I do now? Do they make a 6x16 gear that is .825 OD?
-mike
-mike
