Mine is leaking even with the double seal. I need a new housing along with a quick sleeve. can anyone recommend where to get one?
why do you need a new housing? Are you sure its leaking from that area? It can also leak from the actual speedo drive, or past the parking brake drum splines. Also, if you t-case output is not shimmed properly it can leak no matter how many seals you install...
Lastly, make sure your t-case vent is functioning properly, so you may need to remove it to clean it out.
