Speedo drive sleeve
So mine was leaking and I ordered the orings and shaft. As it turns out it is a different sleeve. My dealer has the seal and oring, but I'm confused if this style is old or new? My 82 parts truck has the same one as on my 82.
There are more designs, I used this for my HJ60, the installation text might help you? :
GEAR SUB-ASSY, SPEEDOMETER DRIVEN (MTM)
33403-69075
FJ6*, HJ6*..MTM..CBU, 歯数=16,マーク 16:6, N=16, MARK:16X6
$35.11
file.php
Here is the kit I ordered. But on my sleeve type there is a seal inside not an oring.
Yours (if that is you picture) and mine (5 speed, 1985 definitely my picture) are type A
Maybe someone confused the parts and made a fixup wich does not belong together.
o SEAL only 1 part, the rest might be why it leaks, might remove that rubber and see if it stops leaking, there is just splash/dripping oil behind it.
And if you have pressure then the air breather might be clogged.
O RING two parts comes with collar AND gasket (fluffy ring)
Hope you sort it out, you have an automatic? The part seems to belong to other models like corolla :bang: :meh: :smokin:
http://www.jp-carparts.com/toyota/partlist.php?maker=toyota&type=191110&cartype=69&fig=3505
90310-09001 / SEAL, OIL (FOR ATM SPEEDOMETER SHAFT SLEEVE)
http://www.japan-parts.eu/toyota/eu...s/3505_speedometer-driven-gear-atm?pnn=35404E
picture of my 5-speed:
file.php
Yeah I got it sorted. I just wanted to post it up because I searched and searched and didn't find much. The first pic I posted was the only one I found with the oring and oil seal and part numbers.
My type only gets the oring and inner oil seal. No more leak...there anyway haha
