Spacers... best place for them?
St. Petersburg, FL
I want to run the Tundra BBS wheel, but I remember hearing they need a 10mm spacer to clear.
I feel like 10mm is a bit wide to install just a spacer with no bolt extender.
Ideas on what everyone out there has used?
Personally, I'd run a .75-1.00" proper hub centric spacer. Bora will custom make them for you and they know how to machine for the front hub of the 100 series.
1" is roughly what 25mm?
Without longer wheel studs I would not add a 10mm spacer. You loose nearly a 1/2" of threaded surface area... too much for me to trust. Thus, I'd step up to a true spacer, .75-1.00" would look great too.
