NeverGiveUpYota
Dare me.
My apologies if I'm kicking a dead horse. Trying to get this clear and concise in my head. Talk to me about the options and the layering. I have done much reading... Some say go with the higher end stuff but some say the cheaper products found at Lowes (Peel & Seal) and Home Depot (Frost King foil over foam) do a pretty good job as well.
The layering is where I am a tad foggy. Dry ice to stock bed liner. First layer would be the foil coated butyl mat (for low frequency) rolled with a tennis ball then a layer of the foil covered foam then jute (for high frequency/wind) and lastly the carpet... Am I on the correct track? Some threads say if there are gaps in coverage then sound will simply make its way to that unlayered area and vibrate through? Is it a matter of how nit-picky I want to get?
You really don't need 100% floor coverage with the butyl mat. It is designed to be a mass loader, and eliminate structure borne noise (ie. rattles).
The foil mats are best used by placing pieces in the middle of the largest panels (ie. rattle focal point... remember the rattle is from a low frequency sound wave). The more the merrier though....
These mats do very little to block higher frequency sounds (ie. wind/road noise)
For the higher frequency sounds you really need a barrier like MLV (mass loaded vinyl), or foam, or jute, or carpet or a combination of those.
Hope that makes sense.
Be cautious with what "sound deadner" you decide to use. Some name brand products are actually crap. I have tested several them and many melted over one summer.
FWIW those "in the know" use a roofing product called "peal and seal". IIRC The newer formulations are high content butyl, much like the good sound deadner products.
It's made to withstand the harshest environments (like on top of a roof). I have installed in in many vehicles, and it is still intact after several years (I live in Arizona... car temps can get up to 180* in the summer). Only problem is that it comes in 6" rolls so the install can be more work. Oh, and it does not smell, at all, like some people claim.
