- Thread starter
- #21
Thanks guys.
You might want to consider the Hakko FX-888 it replaced the Hakko 936. We have at least one if not two 936's on each bench in the factory. I have two on my bench at home, one with a fine tip the other with a heavy tip. Pace makes a similar product, they make good high quality products.
Check out the Pace systems, same construction with the heater in the tip. I haven't used a Metcal station in a while but the Pace stations seem to have a tighter hysteresis loop.Yeah, the metcal stuff is nice. I have an mx500 system and can't imagine using anything else.
The <10 second tip warmup time and the ability of it to put heat at the surface of the tip versus a heater cartridge far from the tip allows for near instant response to temperature variations due to the object you are soldering.
When I've had to go back to using prehistoric cartridge heater based irons like the typical weller/hakko stuff I'm reminded just how superior the metcal system is. But it certainly costs far more than an $80 - $150 soldering station
I've always use a hot air tool to remove SMT parts unless they are near things that shouldn't be heated up too much...
I tend to use 0603 size as my smallest form factor discretes, 0402 is getting a little tiny for my eyes, even with a good magnifier
cheers,
george.
I can't tell you about tip life, but you'd have to be soldering hundreds of connections to see any difference, imo.Does using lead-free solder shorten the tip's life? I had been under the impression that lead based solder was nearly impossible to find nowadays, and that silver-bearing solder as opposed to lead-free was best for electronics/electrical project soldering.
I never even could find a price for the Metcal stations, but they definitely looked expensive as hell. The Pace soldering station I could probably get if I could justify enough projects for a $415 station.
I find it interesting though that Pace makes a point of talking about lead-free solder. Does using lead-free solder shorten the tip's life? I had been under the impression that lead based solder was nearly impossible to find nowadays, and that silver-bearing solder as opposed to lead-free was best for electronics/electrical project soldering.
More crap for me to deal with.Lead free solder melts at a higher temp and requires a more aggressive flux which affects tip life.
Pace talks about Lead free because of the European RoHS initiative which bans lead in electronics assemblies (Japan has a similar ruling.) So far this hasn't been an issue in the US but most electronics suppliers are complying with the lead free initiative as a matter of course. So commercial manufacturers want soldering irons that can work at the higher temps required by lead free solder.
If the Europeans and Japanese got their heads out of their asses and realized that electronics use less than 1% of the lead annually world wide we could stop spending $$$$$$ of extra cost on lead free processing. BTW cars and appliances use the other 99% and are largely exempt under the RoHS initiative.
Sorry, I'm a bit passionate about this topic, but it has caused me no end of unnecessary grief. Now they have come up with yet another POS bit of regulation called REACH.More crap for me to deal with.
As was mentioned above lead based solder is not used in plumbing and hasn't been for many years.
I prefer lead based solder for electronics because the lower temps allow for easier soldering and induce less stress on components. Bottom line; go to Radio Shack and get a spool of 63/37, it will be the best choice for most automotive work.
