- Year
- 1999
- Vehicle Model
- LX470
Asking $8000. Drives like new. 237k. I have an extensively detailed service history spreadsheet I can send, as well as corresponding receipts I can show you in-person.
Serviced replaced components include: hydraulic suspension swapped out with Old Man Emu static setup, timing belt and water pump at 210k (previous owner), brake booster (previous owner), brake pads and rotors, battery, alternator, all fluids (including all three differentials), rack and pinion steering, ball joints, steering tie rods, CV axles, sway bar links, driveshaft U-joints, four wheel alignment, O2 sensors, thermostat tees.
Comes with rubber Goodyear floormats and the factory cloth floormats and a Tech Stream cable. I have a drawer system I built for the cargo area that can be included if buyer desires.
AHC hydraulic suspension has been removed and replaced with ARB Old Man Emu 1.5" Medium Load Kit" for stock ride height, with a Slee Differential drop kit to maintain stock differential/axle components. Suspension changed at 230k in 07/2019 and has 3 year warranty for parts and labor from 4 Wheel Parts.
Oil changed every 5k miles with Mobil 1 5w30 High Mileage Synthetic, and would use the "drain and fill" method during oil changes to also change ~5qt of transmission fluid with Mobil 1 Synthetic ATF. All 5 tires replaced with BFG All-Terrain KO2 LT285/70R16 at 228k.
