- Location
- United States
For Sale - My wife and I are seriously downsizing so this must go
1986 Desert Sand? with Brown Interior Toyota Landcruiser FJ60LG-KA, built June 1986
Priced to move with all the spare parts included at $8500 OBO in Minneapolis/St. Paul MN.
I'm the second owner. I purchased the FJ60 from the original owner in Texas in 1999.
Stock 2F with all of the original emissions components.
Stored Winters, never driven in snow, salted roads or salt water.
picture gallery - This is where I will be posting additional pictures
Compression tests done by LCR4WD within the last 2000 miles were:
VIN:
JT3FJ60G7G1134486, clean carfax
Miles:
178,000 at purchase (July 1999)
195,766 currently (May 2019)
Mods
- ARB Front Bull Bar Winch Bumper with Warn M8274-50 winch
- ARB Rear Step Bumper with Receiver
- ARB Hi-Lift adapter
- ARB Full Size Roof Rack
- OME Front Springs (Heavy)
- OME Rear Springs (Heavy)
- OME shocks and steering stabilizer (N85, N88, S024)
- Poly bushings with zerk fittings
- Larger Swing-Away Exterior Side Mirrors (have OEM originals)
- Tuffy Locking Console
- IPF Headlights, 80/110 Bulb, Headlight Loom Kit
- 4.11:1 Differentials + Lock-Rite Rear Locker (re-geared to OEM spec with 33" tires)
- BFG 33x12.50 R15LT Radial Mud Terrains on Black Wagon Wheels
- Cloth Seat Covers
- K&N Air Filter
- Pioneer In-dash receiver (previous owner installed)
- Grab bar for front passenger
Maintenance History
May 2019 (mostly PM):
- Gas tank renu by Gas Tank Renu | Stop Rust Permanently (interior only)
- New Fuel Pump & spacer
- New Fuel Filter
- New Fuel Sending Unit
- Rebuilt OEM carb
- Stainless Steel Battery Tray
- New Lug Studs and Lug Nuts
- Diffs, tranny, transfer case drain/flush and fill
- Oil and Filter change
Previously:
- OEM Power Steering Pump
- Remanufactured Power Brake Booster
- Clutch Master Cylinder
- Clutch Slave Cylinder
- Valce adjustment
- Water pump
- Distributor Cap
- Rotor
- Ignition Wire Set
- All vacuum hoses replaced
- Spark Plugs
- Oil Pan Gasket
- New Windshield
- Complete Axle rebuilds Front and Rear, includes knuckle bearings and all seals
- U Joints
- Rear Drive Line
- Front axle
In May 2019, I verified with Toyota Customer Care that this vehicle is still eligible for the Toyota rear seat belt recall and that the gas tank recall was done by the previous owner.
Stuff, Spare Parts, and Miscellaneous (included)
And if you've read this far, I am also including all of these items (remember, we're downsizing):
- Factory tool kit, jack, lug wrench
- 'X' style lug wrench
- Spare Aisin OEM carburetor
- Toyota OEM (FJ62) 4.11:1 Open Rear Differential (spare, used)
- Full size mounted spare tire
- ARB 3500080 indicator kit (NiB)
- OME N88 shocks - Rear (2 NiB)
- OME N85 shocks - Front (2 NiB)
- OME S024 steering stabilizer (NiB)
- SOR (p/n 290-66) Rear HD U-Bolt skid plates (1 set NiB)
- Spare front headlamp surrounds (L&R) including blinker lenses with gaskets
- Warn Recovery Kit in Warn Red Cloth Bag
- Set of 4 tire chains for 33x12.50 tires (NiB)
- Toyota 31321-3600 Rubber Pedal Cover (clutch/brake pedal?)
- Toyota OEM Distributor, Igniter, Wires (spare, used)
- 2 sets of wiper blades (NiB)
- 2 OEM distributor caps (NiB)
- 2 OEM rotors (NiB)
- 2 OEM fuel filters (NiB)
- 2 sets of spare belts (NiB)
- 2 sets of spark plugs (NiB)
- Toyota Manual Throttle Cable AKA poor man's cruise control (new, never installed)
- IPF 630RV 4.5" driving lights (set of 2 new in box)
- Max Ellery's Landcruiser 1969-1990 Repair Manual
- Toyota Repair Manuals:
- 36104E 2F Engine Repair Manual
- RM36043 2F Emissions Control Repair Manual
- 36262E Landcruiser Heavy Duty Repair Manual
- 36274E 1985 Engine, Chassis, Body, Electrical, Specifications
- Specter Repair Manuals:
- 223-02-86 Maintenance Procedures
- 223-08 4 Speed Transmission
- 223-25 Front Axle Maintenance
- Specter Off Road 50th Anniversary Edition Coffee Table Book (sweet!)
- 7 Black/White poster sized copies of early Landcruiser magazine ads (circa 1970, suitable for framing)
- and I'm sure I'm leaving a bunch of stuff off of this list
| Cylinder | 1 | 2 | 3 | 4 | 5 | 6 |
| Dry | 165 | 165 | 160 | 160 | 155 | 165 |
| Wet | 180 | 180 | 175 | 180 | 180 | 180 |
VIN:
Miles:
Mods
- Cloth Seat Covers
- K&N Air Filter
Maintenance History
- New Fuel Filter
- Rebuilt OEM carb
Previously:
- Valce adjustment
- Water pump
- Distributor Cap
- Rotor
- Ignition Wire Set
- Spark Plugs
- Oil Pan Gasket
- New Windshield
- U Joints
- Rear Drive Line
- Front axle
