For Sale SoCal 1FZE engine parts and everything else under hood except the long block
Status
Not open for further replies.
Deathvalleypaul
FJ80 Collector
Near Pasadena CA
All other external and internal parts are available including oil pans, crank pulley. Wire Harness, fan and fan clutch, pulleys, complete exhaust, manifolds, down pipes with cats, muffler, alternator. Starter. Oil cooler. Front cover plate, valve cover, fan, head bolts, distributor, injection, intake and exhaust manifolds, sensors, ETC.,ETC,
ALSO Header Panel, Hood Hinges, Inner Fenders, Sensors, Battery Box,
IF IT IS UNDER THE HOOD, I PROBABLY HAVE IT, All but the long block.
Hey Paul, OBD1 or 2?
Yes, however it is from a 96 LandCruiser. The engines are the same in every way, and the connectors are the same. Are you looking for the loom that originates at the ECU? I have it and there are no cuts or removals from the harness. Do you need the sub harness that feeds the injectors as well?
Hi Paul... Yes to both - from ECU and to injectors. I'm local in SOCAL and can come to pick up. Please send personal messages on pricing for one/both wiring looms Thanks!
Your message box is full. Please clear some space and let me know, so I can send you a reply, and send a message so I can send prices and phone number to you. Parts are already out of the car and ready to go.
Yes, I have it $35 local pickup, Temple City, CA 91780, Estimate on shipping to Hawaii is upward of $40. I will have to research shipping to 808.
Oil pans upper and lower from 95+ it needs the crank position sensor bung. Thanks
Easy, please see your personal Mud message>
Status
